Were to get carb parts ?
- TwoSeven
11 Jan 2007 16:51
I noticed there are already a couple of posts on people asking where to get carb parts etc (other than direct from kawasaki).
Since I am about to go thru the same process myself I was wondering if it would be worth while sorting out a FAQ or something for each model of carb used, the parts and their part numbers - mainly so that at least us nubs know what to order when we do need to go to a bike dealer.
Anyhow, on my kz440 the carbs are marked 1281 TD15 and are 36mm Keihin CV units. I need to order a new slide diaphragm as the one in #2 carb is split and the slide is not lifting properly. Does anyone know the actual make and model that the carb is so that I can look around for alternate sources (ie. other bikes).
Also, the jet kit listed on the Z1 enterprises site for the kz440 is different (missing a jet) from whats in my machine - hence it would be easier if I knew the part numbers.
- 77KZ
Re: Were to get carb parts ?
11 Jan 2007 17:22
Kawasaki has an area on their web page listed as "Owner information". With a bit of searching you can find the all the parts diagrams for your ride. Here is the URL
Good luck!
Good luck!
"What do you mean we can't change the alphabet to W,X,Y,K,Z!"
Western, OH, Formerly... Western, NY
1978 KZ650B, 1979 KZ650C, 1978 KZ750B, 1982 KZ750 LTD, 2006 ZX-6R, 2009 Ural Gear Up, 1974 Yamaha DT360 (It's Green Anyway!)
- 77KZ
11 Jan 2007 17:24
OK so once again I have unsuccessfully post a link!! Go to:
www.buykawasaki.com
and on the left sidebar you will see "Owner Info" select that and the from the dropdown select part diagrams. Search for your bike.
www.buykawasaki.com
- TwoSeven
11 Jan 2007 17:40
Thanks for that - I found the Kz440Ltd which uses pretty much the same carb - so have part numbers at least.
- grace1
12 Jan 2007 04:02
g,day to my kiwi mate from the other isle across a bit,
try ebay.com mate there are heaps of 400 440 bits on there
good luck
good luck
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
