TB size...GPZ 1100.
  • tnutz
  • tnutz's Avatar Topic Author
TB size...GPZ 1100.
10 Jan 2007 16:37
#104811
For my own knowledge, who can tell me what size the TB's are on a gpz 1100??? i think i read that mikuni 33's will fit the stock TB holders am i correct?
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: TB size...GPZ 1100.
10 Jan 2007 17:24
#104821
just looked in the fsm. no info on tb size for b1 or b2
suggest hitting buykawasaki.com and comparing carb holder pn's between carbed and FI models.
i can measure on next visit to workshop
could use another set of TB's if you are disposing of yours.
-Duck
  • tnutz
10 Jan 2007 18:14
#104825
not yet, my FI works awesome still...but just gathering info for future...If it quits i am ready. Measure for me if you get a chance. I will try to find it still.
Post edited by: tnutz, at: 2007/01/10 21:16
  • tnutz
10 Jan 2007 18:25
#104829
same part# between CSR1000 or kz1000M1 and Kz1100b1....anyone?
  • steell
  • steell's Avatar
10 Jan 2007 18:31
#104831
I have no idea if the 33's will fit, but I do know the GPz1100 throttlebodies fit the KZ1000J/K/M carb holders (intake manifolds).
BS34's will obviously work, cause that's what the J/K/M use.
  • tnutz
10 Jan 2007 19:04
#104842
is that a mikuni as well, thanks for that info. AND, for that matter, what all has to be added to change to carbs? Ignition should be fine how it is right? Add a choke lever somewhere? what else?
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
10 Jan 2007 19:39
#104848
I'm 430 miles away from my bike right now, and won't be home until friday evening. But if nobody else has posted the measurements by then I'll go out with a caliper and measure. OK?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • tnutz
10 Jan 2007 19:44
#104851
werd...not a big deal anyways i just stockpile info in my spare time...i wouldn't be doing this but i fixed everything i can think of on the gpz except one electrical connecter that can wait till spring..:whistle:
Post edited by: tnutz, at: 2007/01/10 22:45
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
11 Jan 2007 01:30
#104890
I currently have my TB's off my bike. The ID on the TB manifolds is approximately 38mm. The maximum OD on the TB is 40mm. I have been told you must replace your TB manifolds with different ones to switch to carbs (BS34's). :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • tnutz
11 Jan 2007 18:07
#105054
alright, that has been filed in my brain, thanks
  • steell
  • steell's Avatar
11 Jan 2007 19:10
#105081
Maybe there is some difference in the manifolds (carb holders) other than size?
I know the GPz1100 throttle bodies fit perfectly in the KZ1000L/K/M manifolds, because I have both kinds of GPz1100 throttle bodies and a set of brand new KZ1000J/K/M manifolds. And the GPz750 Turbo owners use the J/K/M manifolds when they install the 1100 throttle bodies on the 750 Turbo.
I just realized (totally off topic by the way), that I have entirely to many sets of throttle bodies, and don't have a bike converted to EFI yet.
One set of early 1100
Two sets of late 1100
one set of 2000 GSXR600
One set (just bought on eBay a few minutes ago) 99 GSXR750 (The right size for my 750 twin, if my measurements are correct).
I am going to have to hunt down one of those rountuits that I'm sure are hiding around here somewhere :(
  • tnutz
11 Jan 2007 19:13
#105084
cause when i checked part #'s they were the same for a carbd bike and the EFI.
