boiling carb to open passageways
  • djk
  • djk's Avatar Topic Author
27 Dec 2006 06:11
#101942
Has anyone heard of boiling a carb body in gas and oil to open passageways? The right hand carb doesn't work, yet I can spray carb cleaner through the jet passageways and the carb cleaner comes out where it should. A friend suggested boiling the carb.
Any suggestions?
1981 KZ440A KEI HIN carb a CV 36 I believe. Stamped on the body - 1391 TJ21.
  • Bluemeanie
  • Bluemeanie's Avatar
Re: boiling carb to open passageways
27 Dec 2006 06:22
#101946
I've never heard of that combination but I would be pretty nervous "boiling" it :huh:
  • JMKZHI
  • JMKZHI's Avatar
Re: <<<>>>Berrymans chem dip
27 Dec 2006 06:24 - 22 Feb 2013 11:52
#101947
Last edit: 22 Feb 2013 11:52 by JMKZHI.
  • OKC_Kent
  • OKC_Kent's Avatar
27 Dec 2006 07:15
#101956
Use a carb dip, take the carb all apart, do not soak the rubber parts. Get the carb dip at any auto parts store.
Please do not boil it in gasoline and oil, I'm sure your friend misunderstood the process.
Maybe your friend was hungry at the time, and thinking about a "crab boil" :lol:
Cashion, OK
78 KZ650 B2 85,000+ miles
  • unkle fester
  • unkle fester's Avatar
27 Dec 2006 07:40
#101963
I boil them in a combination of water and lemon juice...the agitiation of the boiling water along with the acidic properties of the lemon juice works wonders....I boil them for about 15 minutes..then dunk em in some clean water to rinse then blow out with compressed air.....before and after pics...... [img size=480]
Post edited by: unkle fester, at: 2006/12/27 10:40
  • unkle fester
27 Dec 2006 07:44
#101964
another pic....
27 Dec 2006 08:54
#101972
djk wrote:
... The right hand carb doesn't work, yet I can spray carb cleaner through the jet passageways and the carb cleaner comes out where it should....
Doesn't sound like the passageway is clogged. Am wondering about more details and description as to what "doesn't work", as the problem may be something other than a carb problem (how about the ignition, spark, timing, valve clearance, plugs, all of which should be checked before blaming the carb); but if truly a carb problem, could relate to jetting, float level, enrichener circuit, etc. Diagnosis is more difficult without more info, for example whether the subject cylinder is even firing during cranking, will the motor crank at all, etc.
BTW, thanks, uncle fester, for sharing the lemon-water boil technique and the pics.
  • djk
27 Dec 2006 19:24
#102121
Thanks, the pictures really looks good - I will try boiling them in water and lemon juice. What portions of water to juice?
Patton, I am sure of the ignition system working properly; timing and valves double checked; new and old plugs used. As a last resort to prove the carb problem, I pulled the pair of carbs off the engine, and mounted the left hand carb on the right hand cylinder and ran the engine only on the right cylinder. The problem with the right cylinder went away.
  • KZ250LTD
  • KZ250LTD's Avatar
27 Dec 2006 19:32 - 04 Aug 2009 11:13
#102123
79 KZ1000ST
Past:
Many.
Last edit: 04 Aug 2009 11:13 by KZ250LTD.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
27 Dec 2006 20:14
#102132
JMKZHI wrote:
Boiling a carb in gasoline? Yer kidding, right? I wonder what could go wrong?
I've heard of boiling them in water & baking soda, then thoroughly drying them out using compressed air. Soaking them overnite or longer in carb cleaner is a typical method. One of the KZR members has stated that the NAPA product he uses leaves the carb bodies kinda polished, but I don't know the exact name or even if it's still available (it may simply be the NAPA carb cleaner). I used the Berryman's.
JMK.<br><br>Post edited by: JMKZHI, at: 2006/12/27 09:29
Exactly what I do, and it works great.
That lemon-juice thing is un-real...whodathunkit?!:blink:
I also think "Patton" posted some excellent advice.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • Bic Darklighter
  • Bic Darklighter's Avatar
31 Dec 2006 04:24
#102591
I gotta try the lemon boil....
I may finally have found a use for the side burner on my bbq. The wife would kill me if she caught me cooking my float bowls in the kitchen :P:P:P
\'76 KZ900
\'74 KZ400
Thorold Ontario Canada
  • arobsum
  • arobsum's Avatar
31 Dec 2006 06:54
#102600
unkle fester wrote:
another pic....
that is awesome. i will have to try this...and it so happens i just "aquired"
a set of 1974 vm28's to try it on...thanks for the idea!
