boiling carb to open passageways
- djk
27 Dec 2006 06:11
Has anyone heard of boiling a carb body in gas and oil to open passageways? The right hand carb doesn't work, yet I can spray carb cleaner through the jet passageways and the carb cleaner comes out where it should. A friend suggested boiling the carb.
Any suggestions?
1981 KZ440A KEI HIN carb a CV 36 I believe. Stamped on the body - 1391 TJ21.
Any suggestions?
- Bluemeanie
Re: boiling carb to open passageways
27 Dec 2006 06:22
I've never heard of that combination but I would be pretty nervous "boiling" it :huh:
- JMKZHI
Re: <<<>>>Berrymans chem dip
27 Dec 2006 06:24 - 22 Feb 2013 11:52
Last edit: 22 Feb 2013 11:52 by JMKZHI.
- OKC_Kent
27 Dec 2006 07:15
Use a carb dip, take the carb all apart, do not soak the rubber parts. Get the carb dip at any auto parts store.
Please do not boil it in gasoline and oil, I'm sure your friend misunderstood the process.
Maybe your friend was hungry at the time, and thinking about a "crab boil" :lol:
Cashion, OK
78 KZ650 B2 85,000+ miles
- unkle fester
27 Dec 2006 07:40
I boil them in a combination of water and lemon juice...the agitiation of the boiling water along with the acidic properties of the lemon juice works wonders....I boil them for about 15 minutes..then dunk em in some clean water to rinse then blow out with compressed air.....before and after pics......
[img size=480]
Post edited by: unkle fester, at: 2006/12/27 10:40
- unkle fester
27 Dec 2006 08:54
djk wrote:
Doesn't sound like the passageway is clogged. Am wondering about more details and description as to what "doesn't work", as the problem may be something other than a carb problem (how about the ignition, spark, timing, valve clearance, plugs, all of which should be checked before blaming the carb); but if truly a carb problem, could relate to jetting, float level, enrichener circuit, etc. Diagnosis is more difficult without more info, for example whether the subject cylinder is even firing during cranking, will the motor crank at all, etc.
BTW, thanks, uncle fester, for sharing the lemon-water boil technique and the pics.
... The right hand carb doesn't work, yet I can spray carb cleaner through the jet passageways and the carb cleaner comes out where it should....
- djk
27 Dec 2006 19:24
Thanks, the pictures really looks good - I will try boiling them in water and lemon juice. What portions of water to juice?
Patton, I am sure of the ignition system working properly; timing and valves double checked; new and old plugs used. As a last resort to prove the carb problem, I pulled the pair of carbs off the engine, and mounted the left hand carb on the right hand cylinder and ran the engine only on the right cylinder. The problem with the right cylinder went away.
- KZ250LTD
27 Dec 2006 19:32 - 04 Aug 2009 11:13
79 KZ1000ST
Past:
Many.
Past:
Many.
Last edit: 04 Aug 2009 11:13 by KZ250LTD.
- Bad Kaw
- Flying Squirell
27 Dec 2006 20:14
JMKZHI wrote:
Exactly what I do, and it works great.
That lemon-juice thing is un-real...whodathunkit?!:blink:
I also think "Patton" posted some excellent advice.
Boiling a carb in gasoline? Yer kidding, right? I wonder what could go wrong?
I've heard of boiling them in water & baking soda, then thoroughly drying them out using compressed air. Soaking them overnite or longer in carb cleaner is a typical method. One of the KZR members has stated that the NAPA product he uses leaves the carb bodies kinda polished, but I don't know the exact name or even if it's still available (it may simply be the NAPA carb cleaner). I used the Berryman's.
JMK.<br><br>Post edited by: JMKZHI, at: 2006/12/27 09:29
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- Bic Darklighter
31 Dec 2006 04:24
I gotta try the lemon boil....
I may finally have found a use for the side burner on my bbq. The wife would kill me if she caught me cooking my float bowls in the kitchen
:P:P
\'76 KZ900
\'74 KZ400
Thorold Ontario Canada
\'74 KZ400
- arobsum
31 Dec 2006 06:54
unkle fester wrote:
a set of 1974 vm28's to try it on...thanks for the idea!
that is awesome. i will have to try this...and it so happens i just "aquired"
