Palmtune for Megasquirt
  • Dave Sloan
  • Dave Sloan's Avatar Topic Author
25 Dec 2006 01:56
#101660
Hi guys, Merry Christmas to all. Just to give an update on the FI tuning on the 650...
I am using the new palm log logging software on the palm3c, really nice software also has a cool display with about 10 diferent parameters that can be displayed. The PDA's screen shows 4 parameters at once. Log is then downloaded in to the computer and inputed into Megalog veiwer which displays the log and the parameters that you want to look at, but then the really cool thing is that you can select table analyzer and the software will make changes to your ve table to get your AFR to 13.7:1.
I can tune the high load areas of the map using this because the wideband 02 will give usable afr readings through the whole range.
If you want to have a look at the site for more info these are the links:-
www.msefi.com/viewforum.php?f=73
www.msefi.com/viewforum.php?f=25
The great thing about this is that I gdont have to watch the afr on the display and the THS and rpm reading to find out what bin I need to change in the VE table. Must say Im really impressed :woohoo:
Z650B2 - Injected
