Pod People: softening hard rubber ?
- neilage66
20 Dec 2006 19:57
My pods are a little stiff!
I know, it sounds like a personal problem. :laugh:
Picked up some used K&N's for Mikuni VM28's on a KZ1000 and the rubber that clamps to the carb throat is a bit stiff and hardened somewhat.
I have heard several methods for softening rubber such as this and was wondering what will actually work well? Is it heat only or ATF or brake fluid or Hoppes No. 9 or hydraulic oil or Old Stump Knocker...who knows what?
Any suggestions are appreciated.
Post edited by: neilage66, at: 2006/12/20 22:58
- Pterosaur
Re: Pod People: softening hard rubber ?
20 Dec 2006 20:05
Myself, I always spray 'em down individually with a liberal dose of Armor All, then heat 'em up with a heat gun set to *LOW* before jiggling 'em around too much.
Once they're off, I soak 'em in a little pan of Armor All while I'm otherwise disposed, basting them occasionally.
When they're ready to go back on, towel dry and apply a little heat with the gun, and they're nice and pliable.
Always worked for me...
- OKC_Kent
20 Dec 2006 21:18
Someone told me that soaking the rubber manifolds in Silicone tent sealer will soften them up. Spray them down and put them in a ziplock baggie. I have some STP Silicone spray you wipe on car rubber parts that claims to keep rubber door seals, etc., pliable. Seems to work ok too.
Cashion, OK
78 KZ650 B2 85,000+ miles
- mariozappa
21 Dec 2006 05:14
+1 with the silicone, it works good for me on most rubber parts.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- JMKZHI
Last edit: 03 Dec 2008 11:16 by JMKZHI.
- OKC_Kent
21 Dec 2006 10:30
If I can find an old hard boot I'm going to try PB Blaster. On the can it claims to rejuvinate rubber. I do know an old o-ring from the front brake got soaked in it overnight, and it swelled so much I couldn't use it. It got very soft too.
Cashion, OK
- ambergrismooon
21 Dec 2006 11:00
Bite the bullet. Z1Enterprizes and keep the new ones sillyconed so they stay supple! Eventually heat will harden them but you can stave off the effects for quite a while.
- JR
21 Dec 2006 13:34
Cold makes the rubber on the K&N pods stiff. I usually warm them up with a hair dryer or stick them on the central heating vent for a few minutes and that works just fine. In warm weather in the summer I dont have a problem.
- neilage66
21 Dec 2006 15:16
Thanks for the tips people!
I was going to "bit the bullet" as Gris said and buy some new filters for well over a C-note, but I ended up being the only bidder on a used ebay set and won the auction for 25 bucks plus shipping. They are quite clean, but one is ever so slightly smooshed (end to end) and as I said the rubber is pretty hard.
I don't even have the bike yet...will pay it off by early spring (see sig) and get it running asap. There is no air filtration on it at all...hence the K&N's for now...er uhh..then. Think spring. :laugh:
So...
1-baste in Armor All
2-soak in silicone
3-PB Blaster
4-mineral oil
5-bite the bullet
Maybe I'll try some 303 Protectant. Ever hear of it?
Check it out:
303
Pod auction:
PODS
Pictures of my new scoot:
Z1R
Post edited by: neilage66, at: 2006/12/21 18:17
So...
2-soak in silicone
3-PB Blaster
4-mineral oil
5-bite the bullet
Check it out:
303
Pod auction:
PODS
Z1R
- ambergrismooon
21 Dec 2006 15:44
A c-note! $100 for 4 boots! Damn!
Use them hard ones to make a clay mold and then mold your own. I see riches in your future!!!
- neilage66
21 Dec 2006 15:56
No Gris...not boots (although 2 pair for 100 would be great for Lacrosse or Redwings)...pods dern it...pods I say!
Remember Invasion of the Body Snatchers...the original and the remake? Thems were nice pods too, only different.
- kzwolfsr
21 Dec 2006 16:08
I recently discovered alchohol softens rubber but only for so long and it swells when soft, but it returns back to the original hardness when dry. So I guess you treat it like skin when you take it out of the alchohol and apply some armorall to keep in the moisture. I did my discover with a 5 year old or more fuel line that hardened
Original man of the Caribbean
