Zukiworks build's a ZRX
- zukdave
Re: Zukiworks build's a ZRX
26 Nov 2017 05:44
Well I've had some time to mess with this and got to take it for a little test ride last night.
I still need to go by Dan's and get an air box setup then will be able to get it out for a real test ride.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- spdygon
29 Nov 2017 18:36
What did you do with the green white and purple tank and the Muzzy pipe that came with the zrx?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- zukdave
30 Nov 2017 05:04
Long story on that but I did some trading with Will I got this bike from that I ended up with the black tank and left side Muzzy
pipe and both the ZRX and the ZX-11 for free.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
02 Dec 2017 06:34
Was able to get this out for a shake down ride last night put about 10 miles on it with no issue's.
Did a few part throttle test hit's and with no burnout on a cold tire/street it wass lifting the front wheel through
second gear and pull's real strong.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
09 Dec 2017 07:03
Last Sunday got to spend the day going some cleanup and paint touch up on the motor.
Rad. and screen cleaned and repainted.
Pulled the header off and hit it with some Works bowl cleaner and a green scotchbrite pad.
Before.
After.
The black tank just looked to out of place to me so hit it with some gray primer.
After that got out for a little ride with my buddy Dan
Before.
After.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- bluej58
10 Dec 2017 06:48
Your header cleaned up great!
Are they stainless?
Who's bike is faster, yours or Dan's?
Are they stainless?
78 KZ1000 A2A
- zukdave
10 Dec 2017 07:09
Yes it's stainless.
As far as faster don't know yet we haven't ran them but Dan's is stock with a pipe,
pods and a jet kit and should make mid. to high 90's hp at the tire and I'm thinking I shoud be about 130 + hp at the tire.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
10 Dec 2017 17:03
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- DoctoRot
12 Dec 2017 14:12 - 12 Dec 2017 14:13
Wow that header looks awesome! I have a super crusty stainless Yoshimura exhaust I need to clean up Ill give that stuff a try. Its so oxidized in places it looks black, I think it had header wrap on it at some point.
Last edit: 12 Dec 2017 14:13 by DoctoRot.
- zukdave
12 Dec 2017 19:35
I've read about using it on stainless and this was the first time I tried it.
Using rubber gloves I poured some on the scotchbrite and scrubbed the pipe then a water rinse. took about an hour's time.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- DOHC
- Those Doe-Hawks really go!
12 Dec 2017 20:49zukdave wrote: Pulled the header off and hit it with some Works bowl cleaner and a green scotchbrite pad.
I was curious, so I looked up the MSDS for The Works Toilet Bowl Cleaner. I just thought I'd mention that the active ingredient is Hydrochloric Acid. I don't have any opinion about that, but I figured maybe someone else might be curious as well. Using gloves seems like a good idea, as well as a thorough washing of the parts after cleaning.
The Works Toilet Bowl Cleaner SDS
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- DoctoRot
14 Dec 2017 08:12
hydrocloric acid is super cheap, i have a bunch of it for cleaning gas tanks, maybe Ill give that a try.
