Spark plug reading
  • harleeblue
  • harleeblue's Avatar Topic Author
Spark plug reading
19 May 2015 18:54
#672787
Trying to tune top end my kz 1000j in a tractor pull this is a picture of my plug wide open top end.well about 7000 rpm with a small flutter.what do you think. I need some advise if anybody could help me out. Stock motor with open pipe stock main jets, with bigger pilots!!!
bradley frantz
  • turboguzzi
  • turboguzzi's Avatar
Re: Spark plug reading
28 May 2015 07:28
#674167
would say it's fine, even if it's a bit on the edge of lean....
maybe go +2 to +5 on the mains and see if you get more of a grey ring on the bottom of the insulator?
not a tractor pull expert by any means, just a road racer....
  • jakedude
  • jakedude's Avatar
28 May 2015 13:11
#674210
Looks good to me. Like fresh baked bread.
Nothing lasts, nothing is finished, and nothing is perfect.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 May 2015 13:54
#674220
Be better off with a HD motor for a tractor.
28 May 2015 14:06
#674223
swest wrote: Be better off with a HD motor for a tractor.
Or even for a tractor trailer......
Attachment 00003a-41.jpg not found
:laugh: :laugh:
  • zukdave
  • zukdave's Avatar
28 May 2015 15:47
#674245
To me it's lean go up two size on the main jet's.
Also with this ethanol blended fuel it does not color plugs like gas did back
when these old KZ's were built.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
