Long arm ?
- les holt
Re: Long arm ?
25 Nov 2013 17:49
Learning curve dude!! I bet that ole "Dunlop" didn't hook worth a squirt! Get a lockup clutch, practice that 60' leave and you'll be busting off some good tunes!!!
I took an 80 Ltd 750 with a 4" over arm, stock shocks, first over gpz pistons, gpz cams, ported gpz head, 29 smooths into the high 10's almost 20 years ago. Don't know how but that crazy little thing was flying!..
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- zukdave
Re: Long arm ?
25 Nov 2013 18:37
I've got about 400 pass's on this bike and a little over 100 on this setup.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Re: Long arm ?
02 Dec 2013 16:42
So KZ10006 hooked me up with another GPz arm
should be here in the morning.
plan on adding 3 1/2" and since the Gpz arm is 2 1/2"
longer then the 650 arm so 6" over the 650 arm.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 4TheKZ1000
- zukdave
Re: Long arm ?
03 Dec 2013 19:21
Got the arm today but thinking it will be after the first of the year
til I do the long arm.
Holiday's gonna take up the money and I still want to go run some
1/4 mile pass with the bar then do the swap.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Re: Long arm ?
05 Dec 2013 00:30
Got started on the swing arm mod.'s
First cut.
Next cut to take the bend out. Cut three side's and used the press to streighten the
bend.
First cut.
bend.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Re: Long arm ?
18 Dec 2013 17:20
Been workin on this some more talked to Mac the welder dude
he's good to weld it when I'm ready.
Pulled the arm off the bike tonight so should get it cut tomorrow
then finish the setup jig deal to hold it all together.for welding.
Going to add 5 1/2 inch and that will pt the bike 8" over stock.
Mac said if I get it to him Saturday afternoon I should have it back for X-miss.
I'll get some pic's tomorrow.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- z1kzonly
Re: Long arm ?
18 Dec 2013 19:31
Hey Zukdave, you are the man! You do it! Just don't talk! Your livin the dream! And having fun!
Here is some reading for you. Here is some stuff, not alot know about. Some blogs from the infamous bike builder "Puppet" He passed in 2010.
This is his longtime friends website, Gary Larson. It is " www.stripbike.com . "He has some Puppet chassis designs.
Go to this site, scroll down on the left side untill you see this:
Puppet's Chassis Design #1 #2 #3 #4 #5 #6 #7 #8 #9 #10! * Enjoy!
RIP PuP!
And look under the legends page. Pup built the chassis's for the fastest Harleys and Jap Fuelers in the day!
And to this day! Kory Hogans 250MPH, Elmer Tretts and Larry McBrides chassis'.
Good reading!
Keep up the Fun! and Fabrication!
Marty in Buffalo, NY
RIP PuP!
Good reading!
- zukdave
Re: Long arm ?
19 Dec 2013 19:40
Ok here's the pic's and how I did it.
The stock KZ650 arm and the stock GPz arm.
Whipped up this little jig to hold it.
Use'd some spare ecentric's and the swingarm bolt for a way to hold the arm to start with.
Cut the end's off the GPz arm and started fitting thing's back together
Got a little long at first.
Ended up at 8" over stock wheel base adding 5-1/2" to the GPz arm.
Stock arm VS GPz long arm.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Re: Long arm ?
28 Dec 2013 00:13
Just got off the phone with the welder he said bring it over tomorrow
afternoon and he'll get it welded up this week.
Also talked to Rob at Z1 about chain since I'll need to add
about 12" to the one I'm running now.
It suck to have to buy a whole chain at about $170.00 just to cut 20 or so link's off so Rob said let
me call you back in a few ok cool
Rob call's back said he found a 30 link piece of the same type chain he could hook me up with.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 4TheKZ1000
Re: Long arm ?
28 Dec 2013 08:38
Hey Zuke,
Did you slug the spliced area or just weld spliced ends together?
- zukdave
Re: Long arm ?
28 Dec 2013 14:09
Sleaved with solid bar stock.
Just dropped it off at the welder's he said he might just do it
tonight and I could have it tomorrow maybe.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
