Drag strip trip.
  • riturbo
  • riturbo's Avatar
Re: Drag strip trip.
31 Jan 2016 02:55
#708687
Great thread Dave . Great guy . Got to meet up with Dave last year at the bike show in Austin . Had a good time .
Hoping to make the GP race again this year . Do they do that show every year .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • zukdave
  • zukdave's Avatar Topic Author
31 Jan 2016 03:34
#708691
Yes they will do the show again this year I'll post the info. as soon as I see it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • zukdave
06 Feb 2016 16:40
#709765
Turned out a nice day and had the bike dug out and at my work so put
bad tag back on and rode it to the local ice house.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
09 Feb 2016 15:18
#710193
As some of you know I was having an issue getting my laptop
to load the software to connect with the ign. box so got another laptop
and got it all working.
I can now program all the timing curve's, the RPM window switches to
auto shift the air shifter and kill the ign. on the shift.
[IMG
I can change the graph to show each curve when reprogramming each one.
[IMG
[IMG
The page for setting the RPM switches.
[IMG
Also has a limited amount of data logging. These number's are not right their what was in the box
I need to reset them all and start over.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • bluezbike
  • bluezbike's Avatar
09 Feb 2016 18:59
#710237
I have to say I really enjoy this post and follow it regularly, many thanks Dave.
As for the wheelie situation, is there anything you can do about changing the geometry at the rear to reduce front wheel lift? I know virtually nothing about this but I remember someone (I think it was SBK Racer?) a few years back talking about the degree the swingarm sits to the ground being very important as well as the mounting point of the top of the rear shock to alter the direction of force when the chain loads up......don't know if there's any meat in this 0.02
79 KZ 1000 LTD
  • zukdave
10 Feb 2016 02:37
#710248
Blue I'm putting shock's back on it that should help the wheelie's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
14 Feb 2016 08:15 - 14 Feb 2016 08:21
#710672
Worked with the software for the Dyna 2000 and got it working
so went to the track yesterday for some test pass's and got the auto shift setup working
it's not adjusted 100% but it will shift on it's own so now to find the setting it like's.
[IMG
[IMG
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 14 Feb 2016 08:21 by zukdave.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • zukdave
20 Feb 2016 16:18
#711706
Needing to do something about the wheelie issues and talking with a few buddy's
putting shock's back on would be the best place to start so.
Pulled the shock's off the ZRX made some temp. adapter plate's and
used them for mock up.
480
480
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
01 Mar 2016 08:09
#713208
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: PLUMMEN
  • zukdave
01 Mar 2016 08:12
#713209
Sound clip just for the hell of it.
[IMG
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Mar 2016 12:30
#713257
Sounds crisp. How much longer is the swing arm?
