- Thank you received: 229
Drag strip trip.
- zukdave
clutch at the lever wanted to start pulling right off the grip.
Pulled the cover while changing the oil and reset the clutch arm one tooth
and now the clutch works in the first 1/2" as you pull the lever the way I like.
Round two test ride I did few 1/2 to 3/4 throttle run's through the gear's
this thing pull's hard wanting to lift the front tire on the 1-2 shift on the street.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- zukdave
and heading out in the morning.
Maybe Mr. bad a$$ ZRX will show up so he's got more shit to talk.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
- Thank you received: 11
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- zukdave
kawi810 wrote: Dave did you run it a the track? 1/8 or 1/4 .
Went last night ran 1/8 mile. went 7.40@92.63 that works out to about 11.60 1/4 mile.
Made a few head's up pass racing a 2013 ZX6R and beat him 2 out of three runs.
Motor ran great was getting faster every pass then in elim,s I made it to the second
round had to run that ZX6R and bogged the motor off the line and couldn't quite run him down
he got me by about 1 1/2 bike's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
- Thank you received: 265
Your running a street tire too vs a slick so maybe a few tenths off for that?? Thinking the Bonnevelle bike is geared a little more too I think a 15 tooth front would be about what they were running. 16/48 vs 16/45 for yours. Don't have a clue on what that would do though.
A little jetting, timing, practice etc etc and your gonna get there. Did you degree the cams? I didn't on mine and know there would be a little more power there. Will be following you on this ......... Always planned on this but got way too old way too fast.... not to mention poorer.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- racer54
- Thank you received: 114
- zukdave
Racer I used this calc. to come up with the 11.63 number but I'll take that 11.56.
www.hotrodpitstop.com/tool.php
Right now the rev. limiter in the GPz ign. is stopping it from going quicker
it shut's it down at about 9800 rpm's and the motor should be able to turn 11,000.
Was going 1.70 60 ft and the limiter was making me shift at about 45 ft out.
Friday's my bonus check payday so a Dyna2000 ign. WILL be ordered.
to fix that issue.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
- zukdave
with 3/8's fuel line.the only flow restriction would be the tee at the carb's.
This ain't my first rodeo I've been doing this drag race shit with car's and bike's
for about 40 year's so I got a clue about what I'm doing.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Thank you received: 2744
- zukdave
swest wrote: Bound to learn something. :whistle:
On here I've learned that post whore's spread a lot of misinformation.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
