Drag strip trip.
Re: Drag strip trip.
16 Jan 2015 15:20
Grudge race?
- zukdave
16 Jan 2015 16:37
I'm game if Sam I am show's we can do $100.00 a pass if he's up to it.
He know's I missed the shift's because he asked me what happen after
we got back to the pit's said he saw my bike fall on it's face
but I bet he'll never admit it.
What realy suck's is we've been freind for almost 20 years and
now this bullshit between us over a damn drag race.
I'm not mad at him just think it's funny after knowing about this thread
for almost 3 years he didn't come on here till the last time at the track
and he finally beat me didn't have a damn thing to say till then
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
18 Jan 2015 17:00
Pulled the clutch out today to see if the KZ1000
pressure plate would work and it's a direct swap.
At this point I see no reason why a KZ1000 lockup
would not work.
The clutch it self look's like chit so the APE Track king clutch will be ordered soon.
would not work.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
19 Jan 2015 04:18
Dave, when i get home tonight i will take a pic of my lock up clutch made by grumpy on 750 turbo .its all in the cover and pusher .there is a spacer that goes between the stock cover and engine case.the pusher is extra long .the snow flake should be the same as a kz 1000 .i was thinking you could modify a stock cover by welding a flange in place and making it thicker like they do on KZ's.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- zukdave
19 Jan 2015 05:10
I just missed out on one from the last batch he made
and that's what got me thinking about the KZ1000 lockup.
That and the price with me being a cheap a%% I know
I could come up with one cheaper.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
19 Jan 2015 15:18
now i know why he designed it this way because of the clutch pusher is in the clutch cover.if it was '82 and older it would have a push rod through the shaft.does not leave many choices.
- spdygon
19 Jan 2015 18:49
Zukdave
If u don't mind me asking what was your bike running the 1/4 mile in?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- zukdave
19 Jan 2015 19:44 - 19 Jan 2015 19:49
Spdygon been a long time since I ran 1/4 mile our track's 1/8 mile.
Based on the 1/8 mile time's it should have gone high 11.80's.
My goal is to be the quickest KZ650 in the USA.
Quickest on record was the Denco built KZ650 back in the late 70's
that was said to have went 10.89.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 19 Jan 2015 19:49 by zukdave.
- KZB2 650
20 Jan 2015 12:48
A young lady at Byron dragway back in the 80s was running 10.9s in the summer and 10.7s in the cool weather.
Can't remember exactly the set up but I think folks have talked about her on on here. It was either the 810 set up or the 831cc MTC , 10.5 to 1 , a 400 lift cam, 29mm smoothbores, slick, wheelie bar, struts, header..... not sure about a longer swingarm either. I have a pic somewhere where she had 10.97 on her bike ( was running ET class at that time and was July ....... that's when she told me it would do 10.7s if it was spring or fall.
I talked to her a few times....... I was hell bent on the 831 kit and a 370 lift Andrews cam at that time so I'm sure the 400 lift cam is right cause I remember thinking I'll be a little under cammed if I ever ran her. She was fearless outta the hole hell of a good rider.
Thinking the Denco bonneville article is here somewhere too where they got the 740cc kit in the low 11s and high tens after switching out to alum rims with approx. the same set up ..... cam, carbs, slick etc. That could be what your talking about.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- kawi810
20 Jan 2015 16:07
was she good looking?
The following user(s) said Thank You: PLUMMEN
- zukdave
20 Jan 2015 17:14
KZB2 you are right that's the number's I was talking about.
Thinking if I can get this in the 10.70's/80's no bar street tire all motor
I would have the right to claim it is the quickest in the USA. till proven wrong.
Gonna be a lot of work to do it but it can be done.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
20 Jan 2015 17:21
dave more power to you if i can help let me know i have plenty of parts .my goal to is to put a 810 cc into the 10'ss.you will probally do it before me .
