Making a Kawasaki Z1 race ready. Again
- mark1122
- Keep twisting it
Re: Making a Kawasaki Z1 race ready. Again
09 Aug 2012 15:25
i have a 2001 cbr600 dedicated track bike. it is cheaper to run and WAAAAY easier to ride than a kz.
get as much seat time at track days as u can before u consider racing.
track days r fairly safe untill u deside to pass, and treat it like a race. then things start getting out of control as a novice.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mtbspeedfreak
11 Aug 2012 22:49 - 11 Aug 2012 22:49
2000 ZRX 1100
1976 KZ 900- Daily Driver
Last edit: 11 Aug 2012 22:49 by mtbspeedfreak.
- dbsuperbiker
12 Aug 2012 09:03 - 12 Aug 2012 09:03
use a 10mm sp plug like the little Honda 4strokes, there's barely enuf room without encroaching on the valve seats.
Flycut from the top, drill and tap right on in vertically.
The set-up is the crucial part, as always
Last edit: 12 Aug 2012 09:03 by dbsuperbiker.
- mark1122
- Keep twisting it
12 Aug 2012 10:00
what do u do for an ignition system? can u just run dual leads from each side of the pick-ups to 2 extra coils?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
12 Aug 2012 10:02
At what point do u think it becomes advantageous to run 4 plugs? is it only if u go over a particular compression ratio?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- dbsuperbiker
12 Aug 2012 14:43
yes, an extra set of coils run in parallel with the main coils.
by starting the fire in combustion chamber on 2 sides, the explosion happens more completely, sooner. Flame doesnt have to travel across the chamber to the other side, hence I am using a full 6 degree LESS spark advance...less detonation and more tolerance for high compression. and high compression is where its at!
The following user(s) said Thank You: Bad Kaw, wireman
- mtbspeedfreak
12 Aug 2012 16:10
Ahh I see. Upon a closer inspection, I noticed the second plug boss is indeed smaller. Are there any difficulties with using different sized plugs? Maybe slightly different resistance ratings?
What kind of ignition and coils do you use? Dyna S, Dyna 2000, Dyna III, Kawasaki OEM? Any special ducting to cool the four coils?
Since the main heat-producing process is combustion, having a dual flame front which allows the combustion to happen sooner and more completel, the motor should run a bit cooler wouldn't you think? Or is any possible cooling effect negated by the higher compression ratio?
2000 ZRX 1100
- BlackZ1R
- Kawasaki in my blood
25 Sep 2012 06:15
This is a great thread. 6 degrees less total advance is a lot on an inline 4. Top end power should be up considerably with this mod.
I'd like to see the dyno charts from both set ups fully optimized. Very nice story and thanks for the all the info. Did I say this is a cool thread?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- boatdrinks
25 Sep 2012 07:48
Just got around top reading this thread. Absolutely cool!
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
- mtbspeedfreak
16 Dec 2012 20:07
Arthur, long time no talk! I trust things are good!!!
2000 ZRX 1100
- wireman
16 Dec 2012 20:52Attachment popcorn_2012-12-16-3.jpg not found
- dbsuperbiker
18 Dec 2012 22:10 - 19 Dec 2012 06:23Yep, doing just fine. The Z1 is sitting all tidy in the garage after finishing 2nd 2 weeks ago at the Homestead-Miami Raceway season finale of the Florida Vintage Series.mtbspeedfreak wrote: Arthur, long time no talk! I trust things are good!!!
In recent months I built a new, mongrel 'vintage' front fork/wheel assembly in an attempt to cure the lingering (and lap time restrictive) horrible chatter at full lean in very fast corners. It was a great success. No more chatter and greater confidence at race speeds.
Improvements include larger fork (42mm) tubes, greater overlap into the lower sliders, wider wheel bearing location, larger diameter/hollow axle, double bolt axle clamps, external damping and pre-load adjustment, and stiffer caliper brackets.
Life is Good.
Last edit: 19 Dec 2012 06:23 by dbsuperbiker.
The following user(s) said Thank You: peter1958
