Making a Kawasaki Z1 race ready. Again
  • DoubleDub
  • DoubleDub's Avatar
Re: Making a Kawasaki Z1 race ready. Again
26 Nov 2011 23:46 - 27 Nov 2011 00:26
#490282
Thanks for posting the article! B)
Last edit: 27 Nov 2011 00:26 by DoubleDub.
  • Racecrafters
  • Racecrafters's Avatar
26 Nov 2011 23:46
#490283
Welcome! Now we're getting into to the zone! Giant ports? What's the engine displacement, carb size?
1978 KZ1000 Superbike
1978 KZ1000 Stock
1976 KZ900 Racecrafters replica
1982 GPZ 750
2000 Ducati 748
1978 Suzuki GS1000E Yosh replica
  • DoubleDub
27 Nov 2011 00:29
#490286
Racecrafters wrote: Welcome! Now we're getting into to the zone! Giant ports? What's the engine displacement, carb size?
From the article:
Valves are 39mm intake/32mm exhaust
Pistons are 70mm (1015cc minus compression space consumed at 14.5:1).
Carbs are Mikuni VM33's with 29mm restrictor plates.
  • dbsuperbiker
  • dbsuperbiker's Avatar
27 Nov 2011 03:19 - 27 Nov 2011 03:34
#490294
DoubleDub wrote:
mark1122 wrote: Nice job on the main support plate. very simple and effective. B
Another novice question, what is the failure/flaw the main support plate upgrade is there to help with?
Engine cases crack after about 6 races. High stress from 125+RWHP and abusive riding cause the cases to flex, then crack. The gusset system ties together the center main bearing support, the upper engine case and lower case. In the middle of the engine, the 2 engine cases are independent on the stocker. After this mod...zero engine case failures after 3 seasons :)
Last edit: 27 Nov 2011 03:34 by dbsuperbiker.
The following user(s) said Thank You: DoubleDub
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Nov 2011 09:40 - 27 Nov 2011 10:26
#490312
how do u get in there to drill the case supports?
i have seen some pretty elaborate suports in there.
Attachment main_cap_support1_small.jpg not found
heres another
Underneath the plate you see, there's a block of billet aluminum that extends down to crank cap which bolts on to the four inner studs. This piece ties the cap and upper case with the lower case. The plate on top ties the billet piece to the lower case. There is also a shim kit in between the plate and billet piece that can be used to adjust to the variance between sets of cases (i.e. the unit can be transferred from one set of cases to another if need be).
Attachment crankcapsupportsmall.jpg not found
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 27 Nov 2011 10:26 by mark1122.
  • Old Man Rock
  • Old Man Rock's Avatar
27 Nov 2011 11:25
#490323
"how do u get in there to drill the case supports? "....
Well it sure as hell wasn't accomplished with Harbor Freight tools.... :pinch: :laugh:
Damn I just LUV these images of you guys that can do this type of work, coolness at it best.
RSling, Leon, Irishwill, Testarossa etc.... B)
Keep them images coming no doubt... :)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Nov 2011 12:44
#490327
u mean i cant use my grinder and Drumel ? :angry: :laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • turboguzzi
  • turboguzzi's Avatar
27 Nov 2011 13:46
#490336
hi arthur
never worked on a 1000 so had no idea about this mod
do you know if the smaller 650-750 block should be similary protected to avoid trouble?
they might be more safe as the plain bering crank has dowels in all the cases bearing housing holes
had on my 750/810 just 4 races this season, so far so good, but would be interested to know if you ever saw similar trouble with 650-750's
tnxs
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Nov 2011 14:29
#490343
turboguzzi wrote: hi arthur
tnxs
u may want to run that question by our member, Injected. he dragraces a high compresion, alcohol kz650.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
27 Nov 2011 15:23
#490363
I've never seen the cases braced like that before, it makes sense to me! I'm slowly accumulating the stuff I need for a "go-fast" Z1, those are a great few pics to save for future reference.
Mark, the "block of billet aluminum" with the shims, where'd you find that? I'm definitely interested in hearing more about it if you can provide any more details.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • DoubleDub
27 Nov 2011 16:27
#490372
tnxs
Also interested, although I won't be making nearly that amount of power :unsure:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
27 Nov 2011 17:09 - 27 Nov 2011 17:22
#490380
its not needed on the street. the 1 thing u need to watch out for though, is the output shaft. when u put a 5/8" or longer offset sprocket on and head to the drag strip.u should use a suport bearing and plate in that case.
unless u are using a big tire. or hammering it on every corner of a rd race track u will be fine with out case bracing. most drag bikes with small tires live a long life without bracing.the tire spins up and takes the load off.
i and many others run kz1200's on the street without.
i think Arthur has the right idea.quick and simple. if u can do it without alot of machining and expence it makes more sence.in his case , he has found it to be very nessasary.
the problem is the braces(case webbing) are not flat, they are thicker at 1 end than the other, so most fixes ive seen, involve machining them flat first, so they are 90* to the main cap.
the guy the made the second one , made a few, and there was no demand so he stopped. i can put u in touch with the guys though if u want to order 1 up. but since they are 1 off, u may fair better localy? they build top fuel bikes, and hange at dragbikes.com
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 27 Nov 2011 17:22 by mark1122.
