- Thank you received: 1088
I'm in need of a Junk Z1 - 6 bolt front rotor
01 Jan 2024 04:15 #893380
by hardrockminer
Replied by hardrockminer on topic I'm in need of a Junk Z1 - 6 bolt front rotor
I'll check today. Happy New Year!!
- z1kzonly
- Thank you received: 537
01 Jan 2024 06:59 #893385
by z1kzonly
Replied by z1kzonly on topic I'm in need of a Junk Z1 - 6 bolt front rotor
Let me look. I bought a front rim complete but I don’t see a date on the rotor. Strange!
Hi Matt, Glad to touch on the texter with Ya'
Your disc there in picture? Notice the rivet heads? look a little different? Maybe it was a replacement disc over the years? I'll try and get a better picture of this 8 K coded one. These rivets look like a point dead center of them, with less radius around outer edge?
I'm not in a hurry, I just don't want to ruin an early '8' code disc.
- z1kzonly
01 Jan 2024 07:01 #893386
by z1kzonly
Thanks! Yes, Happy, Safe, Healthy New Year to all also!
Marty in Buffalo
- z1kzonly
01 Jan 2024 07:19 #893387
by z1kzonly
01 Jan 2024 09:53 - 01 Jan 2024 09:55 #893390
by hardrockminer
I checked it this morning. It's a 9K date code (see right side of photo) and I've had it for several years. I originally intended to use it on a Z1B I was restoring but I found another one that was correct for the bike and used it instead. This one was vapour blasted and poorly painted by someone. I haven't checked the thickness but I can do that if it's important. Bolt holes are 10 centimeters apart when measured across the diameter.
Last edit: 01 Jan 2024 09:55 by hardrockminer.
- z1kzonly
01 Jan 2024 19:07 #893417
by z1kzonly
Hi HRM. Date code or thickness doesn’t matter to me.
it is for a vintage drag bike using an Akront 18” laced to a Z1 hub.
my plan is separate it Blanchard grind it down to 4.5 mm.
then turn 3/8”-1/2”? off outer diameter to match a small Gremica caliper. I have to cut axle down, make a caliper bracket to mate of to a 170’s BETOR 35mm dirt bike frontend!
I have a lot of fabricating to do.
plus? Are you in BC? Canada/US border?
thanks for your time digging this up!
marty in Buffalo
marty in Buffalo
02 Jan 2024 04:21 #893422
by hardrockminer
Yes, I'm in BC but not close to the border. I'm about 4 hours from Vancouver, on the Trans Canada (#1) Highway. The nearest city is Kamloops, about a half hour from me.
If you want it, it's yours for $25 plus shipping. My guess on shipping is $50 to shuffle off to Buffalo. Matt may want to do a double trade so I'll wait for his reply.
