  • Page:
  • 1
WANTED! One 29mm 2.10mm valve shim 21 Jun 2023 08:00 #886268
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
  • Thank you received: 34
I have a 2.25mm, a 2.45 x2 and a 2.55 all brand new from Z1 enterprises
Would trade any of these new shims for one good 2.10mm
When ya receive my shim then ship, smooth and simple
please holler
1982 KZ1100D1
WANTED! One 29mm 2.10mm valve shim 21 Jun 2023 09:49 #886272
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 668
2.10 is getting way down there size wise, might be time for a valve tip especially if you have others getting that way.
Z1000J2 somewhat modified!
WANTED! One 29mm 2.10mm valve shim 21 Jun 2023 17:24 #886292
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1040
I probably have one.  Will check tomorrow.  Will also check to see if I need any.
WANTED! One 29mm 2.10mm valve shim 22 Jun 2023 15:41 #886315
  • Gdailey2112
  • 82 KZ1100D1
Yes I know but I was down to nill and tipped several valves. That valve was tipped.
Wil be looking for a good used head if the future.
BTW I actually would be better off with a 2.15mm shim
Thanks for looking around for one. Been 100 deg here and I'm itching to ride.
1982 KZ1100D1
WANTED! One 29mm 2.10mm valve shim 22 Jun 2023 18:32 #886319
  • Gdailey2112
  • 82 KZ1100D1
Disregard please, I had no idea one was ordered by my other half. Communication isn't among her best features lol
1982 KZ1100D1
WANTED! One 29mm 2.10mm valve shim 23 Jun 2023 01:43 #886323
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1473
Will be looking for a good used head if the future.
There's no need to source another head.
If you run out of clearance once you have tipped the valves by the manuals .0.30mm you can skim the collets, retainers and stems by a further 1mm to enable the use of the maximum shim sizes.
Once that option has been used or dismissed you can fit bigger valves which use the wider unused portion of the valve seat and pulls the stem height back into servicable range and after that you can fit shorter J style valves which have 1mm shorter stems to again regain clearance.
Lots of options before getting the seats replaced or fitting another head.
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7, Wookie58
WANTED! One 29mm 2.10mm valve shim 23 Jun 2023 17:59 #886351
  • Gdailey2112
  • 82 KZ1100D1
Thank you Zed! Cuz yes I was also wondering about the options at this stage in the game.
1982 KZ1100D1
  • Page:
  • 1
