  • Page:
  • 1
Kz1000A 17 Jan 2022 14:09 #860639
  • Samminorwich
  • Samminorwich's Avatar Topic Author
  • Thank you received: 1
Has anyone got a top engine casing that will fit ontop of my kz1000A lower casing
kind regards Samantha
Kz1000A 17 Jan 2022 14:55 #860642
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Thank you received: 1972
Not the best way to start a project ..
 The cases are matched sets , meaning during assembly  they are machined ( Line bored )  while together
Not to say you might get by , but not a  proper  way to build a motor
Good Luck
Last edit: by Street Fighter LTD.
Kz1000A 17 Jan 2022 14:56 #860643
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1468
Samantha ! The engine cases are machined as a pair along with the main bearing cap.
You will need to replace the whole lot as a set and not just the top case.
Replacing just the top case has been done in the past ( mostly in racing situations as a last resort  ) but requires careful measurement and professional adjustment to be made possible and even then it isn't ideal or a permanent solution.
What is wrong with your top case half ?
The following user(s) said Thank You: Samminorwich
Last edit: by zed1015.
Kz1000A 17 Jan 2022 16:23 #860650
  • Samminorwich
Or maybe then a pair of lower cases 77/78
and a crank possibly
Re Samantha
  • Page:
  • 1
