VM33 Smoothbores
- Adrian67
26 Dec 2021 11:00 #859619
by Adrian67
VM33 Smoothbores was created by Adrian67
Hi, i am looking to buy parts to complete a set of 33mm smoothbores. I mainly need the main throttle cable bracket (the one that bolts on to #3 carb) and the steel bracket that joins them together (air filter side)
I would also be interested in any other spares you may have laying about as long as they are in good usable condition. Also any VM29 smoothbore parts if anyone has any.
TIA
TIA
- 73z1
- Thank you received: 105
26 Dec 2021 11:37 #859623
by 73z1
Replied by 73z1 on topic VM33 Smoothbores
- Adrian67
26 Dec 2021 11:45 #859625
by Adrian67
Replied by Adrian67 on topic VM33 Smoothbores
Were these parts used on any production bike carbs ?
I would make the parts if none available.
No they were not used on any production bike, but a popular upgrade back in the day for the big Z's and other Jap bikes.
I could probably make the long bracket but i want them to be original if possible. The throttle cable bracket would need to be original, to complex to make.
- Thank you received: 2756
26 Dec 2021 13:28 #859629
by SWest
Replied by SWest on topic VM33 Smoothbores
You can get a lot of parts here but some are discontinued/
jetsrus.com/carburetor/carb_mikuni_VM33_...oded_view_parts.html
- Adrian67
26 Dec 2021 13:36 #859631
by Adrian67
Thanks Steve, i have tried all of the worldwide Mikuni stockists. I know a lot of the parts are discontinued now, but was hoping maybe to find one that had some NOS parts still hiding in their parts drawers. The jets and gaskets are readily available but all of the carb specific bracketry and ancilliaries are sadly no longer available.
26 Dec 2021 13:46 #859634
by SWest
The ones that are somewhat complete are being sold for crazy money. You might try the KZ Market on FB.
The following user(s) said Thank You: Adrian67
- Thank you received: 1918
26 Dec 2021 17:55 - 26 Dec 2021 17:58 #859649
by Mikaw
Replied by Mikaw on topic VM33 Smoothbores
Your only option is finding a parts set. I had the similar issue when I bought a set of 33’s and realized bubba had hacked off one the cable mounts… I looked forever, never found one. I had to disassemble a working set I had to take both to a fab shop and they ended up repairing both. I did notice the one used as an example also was damaged. The threads for the adjuster barrels were stripped.
Last edit: 26 Dec 2021 17:58 by Mikaw.
- 73z1
27 Dec 2021 06:24 #859657
by 73z1
A fabrication shop can make these if they have one for a template.I had to disassemble a working set I had to take both to a fab shop and they ended up repairing both.
