KZ650F KZ750E Muffler System KZ650 KZ750
  • martin_csr
  • martin_csr's Avatar Topic Author
08 Aug 2024 07:44 - 09 Aug 2024 05:27
#902896
KZ650F KZ750E Muffler System. Used. Good condition. $195 Total Shipped.
Looks good but the system isn't perfect.  There are a dozen or more minor flaws, most of which are kind of hidden.
There are minor crease dents on the engine side of each of the headers near the top bends. RH muffler cover has a road rash scrape.
System does not have the muffler hanger brackets. Headers have golden discoloration at the top.
This system is almost as good as the 750E mufflers I have on my KZ650-CSR.
Arrow indicates where road rash scrape is.
Last edit: 09 Aug 2024 05:27 by martin_csr.
  • martin_csr
Re: KZ650F KZ750E Muffler System KZ650 KZ750
08 Aug 2024 07:45 - 08 Aug 2024 08:10
#902897
KZ650F KZ750E Muffler System. Used. Good condition. $195 Total Shipped.  Continued.
Pic showing flaw on inside of LH muffler. Just an example of a flaw and its location.
Closeup of the flaw on inside of LH muffler.
I would spray that with Rustoleum silver bar-b-que grill paint.
Last edit: 08 Aug 2024 08:10 by martin_csr.
  • martin_csr
08 Aug 2024 07:51 - 08 Aug 2024 07:54
#902899
More pics. KZ650F KZ750E Muffler System.
The crease dents. Also, pic seems to show another flaw on #4. I forget what it is; need to check that.
Last edit: 08 Aug 2024 07:54 by martin_csr.
  • martin_csr
08 Aug 2024 08:00 - 08 Aug 2024 08:05
#902901
750E Muffler System on garage floor. compared to 750E system on my csr.
Inside of RH muffler cover. no rust or not much anyway.
Both muffler covers are included.
Last edit: 08 Aug 2024 08:05 by martin_csr.
  • martin_csr
10 Aug 2024 06:25 - 10 Aug 2024 06:37
#903020
KZ650 KZ750 KZ550 Pulsing Coil Cover. Very Good Condition. almost like new. $35 Total Shipped.
Refurbished. It may be nos but the paint was faded and there was some minor shelf wear.
Cleaned, polished, repainted w Engine paint.
Last edit: 10 Aug 2024 06:37 by martin_csr.
  • Nessism
  • Nessism's Avatar
10 Aug 2024 06:36
#903022
That systems is very tempting, martin.  It's hard to find them in that condition anymore.
  • martin_csr
10 Aug 2024 06:50
#903023
It's a solid system.  I need to box it up and get a shipping price to see if I can adjust the price down some.
It didn't have much rust, but I wire wheeled the manifold section some using soft brass jeweler's wire wheels, prepping it for the same paint treatment as the system on my motorcycle. But my dremel suffered the fatal Magic Smoke and I haven't touched it since.  doh.
  • Nessism
  • Nessism's Avatar
10 Aug 2024 12:07
#903050
I've shipped several exhaust systems before, and the key thing is to get the box to fit under the UPS "oversize" criteria.  Something like 106" max, girth + length.  I used two boxes, nested together, pushed to the tightest safe length possible.
  • Mikaw
  • Mikaw's Avatar
10 Aug 2024 13:17 - 10 Aug 2024 13:23
#903058
Attachment not found
This is the system on my 4-80 750E, I’ve been looking for a replacement as the PO hacked out the baffles and welded up the crossover. How close is your set to my original? Does your current CSR have the Sankei system?
Last edit: 10 Aug 2024 13:23 by Mikaw.
  • hardrockminer
  • hardrockminer's Avatar
10 Aug 2024 18:27 - 10 Aug 2024 18:28
#903073
I'm interested if Mikaw doesn't buy it.  I have a 650 project that's been sitting for several years.  It needs an exhaust system.
Where are you located?
Last edit: 10 Aug 2024 18:28 by hardrockminer.
  • Nessism
  • Nessism's Avatar
11 Aug 2024 04:51
#903084
Pretty sure that martin's system is an exact match.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
11 Aug 2024 04:55
#903085
This may be an opportunity to help define the ID or our mystery 4/2 Bassani (?) system.  There's been some speculation it might fit a KZ750.
Martin,
If you could, please, reply with:
Spigot (large collar) OD of the head pipes.
Center-to-center distance of the 1-2 and/or 3-4 head pipes.  Inch OK, mm better.  Same measure of the 2-3 head pipes if different.
Thank You.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
