KZ650F KZ750E Muffler System KZ650 KZ750
Re: KZ650F KZ750E Muffler System KZ650 KZ750
11 Aug 2024 06:44 - 11 Aug 2024 07:37
By Mikaw: This is the system on my 4-80 750E, I’ve been looking for a replacement as the PO hacked out the baffles and welded up the crossover. How close is your set to my original? Does your current CSR have the Sankei system?
The muffler system for sale is stock/oem. one of the pics above indicates the fitment for a KZ650F and KZ750E; the RH muffler is stamped the same. Sankei 2058 is stamped on the LH muffler, same as the 750E system on my CSR, but I don't have a pic, though.
It's a solid system, but as noted in the topic post there are a number of flaws. Most of them are kind of hidden but the LH muffler has a ~1/4" bad spot near the center stand recess, possibly from the center stand banging against the muffler. The RH muffler has a smaller spot below & rearward of the muffler bracket mount. Both are barely visible in a couple of the pics >> I would treat both w silver bar-b-que grill paint.
More pics. Muffler End Caps.
Last edit: 11 Aug 2024 07:37 by martin_csr.
11 Aug 2024 07:23 - 11 Aug 2024 07:32
KZ650F KZ750E Muffler System. Used. Good condition. $195 Total Shipped. more pics. Continued.
RH manifold section.
LH manifold section. same pic as shown earlier.
Last edit: 11 Aug 2024 07:32 by martin_csr.
11 Aug 2024 14:57 - 11 Aug 2024 14:58
I’m assuming the blue tape clamp is for the right hand manifold area to the crossover? I’d like to buy these. No rush to get packaged.
Last edit: 11 Aug 2024 14:58 by Mikaw.
12 Aug 2024 05:23 - 12 Aug 2024 05:45
The blue tape was just to hold the clamp in place to keep it from rattling around while being handled for pics.
KZ650F KZ750E Muffler System. Used. good condition. cont'd. Some closeup pics. Sankei 2058. DGM. chipped chrome, scrape.
Looks good but the system isn't perfect. There are a dozen or more minor flaws, most of which are kind of hidden.
There are minor crease dents on the engine side of each of the headers near the top bends.
System does not have the muffler hanger brackets. Headers have golden discoloration at the top.
RH muffler cover has a road rash scrape. RH muffler has small chips in the chrome in one area and the muffler tip has a scrape. I forgot about the scrape. doh. but it's not that conspicuous. I would treat that and those sorts of flaws w silver high heat paint (I use rustoleum bar-b-que grill paint).
LH Muffler. Sankei 2058. Center stand recess and damaged chrome. possibly from stand banging against the muffler.
RH Muffler. KZ750E KZ650F DGM-36930 identifier.
RH Muffler. Chipped chrome and muffler tip scrape.
Last edit: 12 Aug 2024 05:45 by martin_csr.
12 Aug 2024 05:31 - 12 Aug 2024 05:43
By Mikaw: .... I’d like to buy these. No rush to get packaged.
Okay. But if you change your mind, that's fine. This isn't EB. ha ha.
I guess payment by pay-pal. Or USPS money order if you prefer. I only use paypal to buy stuff from websites and have never done a person-to-person transaction there, but I assume it's a simple thing to do.
Before finalizing anything, I'm going to unwrap the mufflers and take another look and add pics as necessary.
Then box it up. If shipping isn't as bad as I think it's going to be (doubtful), the price will be adjusted downward to my shipping guestimate pricepoint.
Edit. PS: does the private message system work now? I'm not seeing a pm button anywhere.
Last edit: 12 Aug 2024 05:43 by martin_csr.
12 Aug 2024 05:38This message contains secure information
12 Aug 2024 06:00
12 Aug 2024 06:18 - 12 Aug 2024 06:22
Looks like you figured out the PM system
Can you see the "Not sue if the pm system works" message I posted?
It was intended for Mikaw as I clicked reply below his message then clicked private message.
Last edit: 12 Aug 2024 06:22 by martin_csr.
- slmjim+Z1BEBE
12 Aug 2024 07:00This message contains secure information
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
12 Aug 2024 19:00
The following user(s) said Thank You: martin_csr
12 Aug 2024 20:15
I see the same as Tex and Slmjim are seeing. “This message contains secure information”. I’ll try sending you a PM!
12 Aug 2024 20:16This message contains secure information
