School us on metric thread nomenclature, please.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
05 Jul 2026 06:08
#925518
Thread pitch is known 1mm.  Hex size is 27mm.
ID of threaded portion of the the nut peak-to-peak is nominal 19mm.
Is this considered a M20 nut, as in M20x1?
Thanks all !
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Warren3200gt
  • Warren3200gt's Avatar
Re: School us on metric thread nomenclature, please.
05 Jul 2026 06:55 - 05 Jul 2026 07:04
#925519
Yep, m20 x 1. (Aka M20 ultra fine)
Last edit: 05 Jul 2026 07:04 by Warren3200gt.
  • Injected
  • Injected's Avatar
05 Jul 2026 07:01 - 05 Jul 2026 07:03
#925520
Whatever the thread ID measures is roughly the tap drill size, you can confirm size and pitch on any thread chart by cross referencing tap drill size.
1978 KZ650B2 modified project
Last edit: 05 Jul 2026 07:03 by Injected. Reason: sp
  • zed1015
  • zed1015's Avatar
05 Jul 2026 07:56
#925522
No! the thread is measured by the outer diameter of the thread on the peaks.
That thread will be M22 X 1mm.
The inner trough measurement is near enough 20mm and the depth of a 1mm pitch is also 1mm so that takes it to 22mm which is very common for Kawasaki fuel taps and some Harleys etc..
The following user(s) said Thank You: StreetfighterKz, asphalt900, daveo, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 Jul 2026 08:18
#925524
Measuring the spigot on the tank will give the actual size which as zed said is 22mm
  • asphalt900
  • asphalt900's Avatar
05 Jul 2026 09:00
#925525
That's a Honda petcock Jim, what the heck ha. Missing the tower filtering sock and oring but remnants remain stuck to the tower. Yes, Zed's and Wookie's answers are correct!!
  • slmjim+Z1BEBE
06 Jul 2026 05:49
#925542
   It is indeed. Z1BEBE's '93 CB750 Nighthawk.  The filter & O-ring were removed to ease measurement.  NLA from Papa Honda.  Aftermarket sellers claim either M18x1 or M20x1, and one claims M22x1, all for the same PN# for aftermarket petcocks for the same year.  Making us nuts...
   Metric thread nomenclature is brand-neutral and info on same could be useful to anyone here.
   There's no other forum we trust enough to accurately offer this, specific, tech info on metric threads.  The Nighthawk forums aren't on the same tech level as KZR.
   Reading through this thread, there's even differences of opinion here re: size.  Some online fastener / thread charts vary in description, but mostly tend towards M20x1 for the indicated  ID caliper measurement.
   To further muddy the waters (or not), bung threads are nominal 20mm. peak-to-peak, which may make M20 more believable.  Our desire is to get this done right the first time.
Thanks, all.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Jul 2026 06:39
#925543
Guys if that vernier is sitting on top of the threads then it is indeed M20 - M22 is the most common across Kawa, Harley etc (the bung I welded into the tank of my project is M22 in the same spot you are measuring)
  • Nerdy
  • Nerdy's Avatar
06 Jul 2026 13:00 - 06 Jul 2026 13:27
#925556
Would this help in any way?
www.cmsnl.com/honda-cb750-nighthawk-1993...et-cock_16953me5005/
(I don't know what sort of shape the existing petcock is in)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 06 Jul 2026 13:27 by Nerdy.
The following user(s) said Thank You: slmjim+Z1BEBE
  • slmjim+Z1BEBE
07 Jul 2026 04:16
#925567
The outside jaws are firmly seated on the thread peaks of the bung.  The inside jaws are firmly seated on the thread peaks of the nut.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Jul 2026 04:50
#925570
Good Ridin'
slmjim & Z1BEBE
Then it is indeed M20 which ties up with what's advertised on Ebay for CB750, Nighthawk, CB900 etc
  • asphalt900
10 Jul 2026 06:57
#925643
Sounds like we'll be doing pretty much the same Jim! Friend dropped this off. It's the older 1983 650 version but pretty much the same concept. He had bought this somewhere, not running of course. So, fuel system and carbs will all have to be gone thru. When i do these "riveted" selector plate petcock versions i just drill them out and tap the holes with M3 phillips JIS screws. Although selector rubber pucks were never offered separately because of the design, they ARE available.
