Doe Anyone Use One of These Beauties?
  • spdygon
  • spdygon's Avatar
Re: Doe Anyone Use One of These Beauties?
29 Apr 2022 16:41
#866396
Great tool..I’m still little young to work out of the floor
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
29 Apr 2022 17:34
#866400
I only use 3 spoons too.  But the last set I did on my supermoto took forever to break the old bead. Im def buying a bead breaker next set.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
29 Apr 2022 19:21
#866403
I bought a cheapo tire machine from Harbor Fright for $79 a few years ago and threw away most of it so I only use the vice and the bead breaker.
Then I use three 6 inch Motion Pro levers. To protect the rim I cut three rectangles from a Clorox bottle, very tough yet pliable plastic.
For lubricant I use Lemon Pledge though one of these days I'll get some real stuff.
I change them myself but it's much quicker with a second pair of hands. The machine has paid for itself ten times over.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
29 Apr 2022 21:25
#866407
If I had the space, I'd probably get one of these No-Mar machines.  It definitely looks easier than using spoons.
www.nomartirechanger.com/tc-ch100hd-plus.html
There is also this one that looks pretty cool.  Cheaper than a powered machine, but it still uses the same type of touchless arm and ramp.
www.redlinestands.com/catalog/shop-equip...-tire-changer-p-1657
My dad's '74 Z1
'00 ZRX1100
30 Apr 2022 11:50
#866423
The last time I installed new tires I couldn't break the old bead on the rear tire as I had done in the past.  So I used a razor knife to cut the old tire around close to the bead and tossed the tread section.  This left 2 rings of the old tire which then were very easy to remove.  Ed
  • hardrockminer
  • hardrockminer's Avatar Topic Author
30 Apr 2022 12:12
#866426
I had a hard time breaking the bead on my bicycle front tire that I changed for the first time ever yesterday.  It's been in use since I bought the bike in 2008 or 2009.
  • MB
  • MB's Avatar
13 Jan 2025 10:13 - 13 Jan 2025 10:57
#907856
Sorry wrong feed. how do I delete a comment or response?
Last edit: 13 Jan 2025 10:57 by MB.
