Kawasaki KZ 1000 shim tool
- WILLIAM PIPPEN
23 Feb 2016 07:06
Help
I bought the Kawasaki shim tool and don`t understand how to use it on the intake side. Once the bucket is pushed down and the tool installed, you need to roll the cam lobe up so that you can get the shim out. The cam lobe then runs into the tool at the same time it`s pressing down on the bucket. I have been taught to NEVER rotate the crank / cams backward. But that looks like the only way to make this work.
On the exhaust side, the lobe rotates away from the tool and all is well.
What am I doing wrong?
Re: Kawasaki KZ 1000 shim tool
23 Feb 2016 08:09
You'll have to back it up a little. I had one of those years ago until someone else needed it more than me.
Been stuck with the bat wing since. I hate it. I'll get one eventually. :whistle:
- jakedude
23 Feb 2016 10:33
Does your tool look like this?
WILLIAM PIPPEN wrote: Help
Nothing lasts, nothing is finished, and nothing is perfect.
23 Feb 2016 10:39
$50 OUCH. It was $50 in the 70's. :dry:
- PLUMMEN
23 Feb 2016 21:18
Ive always just used a bent screw driver and a home made metal wedge,But hey Im cheap! :woohoo:
- Kapahulu
23 Feb 2016 23:22
Zip ties work for me, I guess I'm cheaper than Plummen.
2strokeworld.com
2strokeworld.com
- OnkelB
24 Feb 2016 02:00WILLIAM PIPPEN wrote: Help
... I have been taught to NEVER rotate the crank / cams backward. But that looks like the only way to make this work.
It's not a problem to rotate the KZ engines backwards, as you say that's the only way to use the factory tool. You will also have to rotate the engine backwards on the exhaust side as you need to depress the bucket after replacing the shim in order to remove the tool.
I have done this several times with no issues, just remember easy does it.
77 KZ 650 B1, 82 GPz 1100 B2.
- Rockranch
24 Feb 2016 06:11
Vroom-vroom!!!
www.z1enterprises.com/product/ZSM001-113
www.z1enterprises.com/product/57001-113
www.z1enterprises.com/product/TU15-0468
$50 bucks sounds cheap after seeing these 2 lmao, and $8 for the bat. ..................................Mikeswest wrote:
Vroom-vroom!!!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
1 modified
24 Feb 2016 06:24
The bat wing is a PITA
I had a bent screw driver and a cut and bent spoon. Worked better than that POS.
I'll bight the bullet and buy a REAL one soon.
24 Feb 2016 07:35Kapahulu wrote: Zip ties work for me, I guess I'm cheaper than Plummen.
Lots of guys on the GS Resources swear by the zip tie method. Personally I use the tool but it's hard to argue with success.
members.dslextreme.com/users/bikecliff/i...lve_tool_zip_tie.pdf
- redhawk4
24 Feb 2016 07:56OnkelB wrote:WILLIAM PIPPEN wrote: Help
I don't think there's a problem turning any motor backwards by hand, the reason for turning it in the direction it runs in is to ensure any slack is in the position it would be in when the engine is running, For example setting the timing on bikes where the points run off the cam, if you set the timing rotating the engine backwards, then when going forward the timing would be out due to the play in timing chain, similarly with a distributor any backlash in the gears would have a similar effect.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
24 Feb 2016 09:23
As long as the cam chain adjuster is working properly and there isn't too much slack in the chain.
