Permatex No 1 Gasket Maker is CRAP!
- clutch
- I wish I had a tad more patience to do it better!
Re: Permatex No 1 Gasket Maker is CRAP!
31 Oct 2011 15:07
I'm thinking jb weld will hold up against gas (and ethanol :sick:). I don't mind making a permanent bond on the plate itself. It definitely would be a pain to get tha stuff into the threaded area, but at this point I want to fix it and forget it. If I have to clean up a little squeeze out quickly with a rag, I will. If it will work, I think it's worth the extra effort to make sure it's cleaned up in there
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
31 Oct 2011 15:09
This is from the JB Weld website:
"Q: Is J-B Weld resistant to water and/or gasoline?
A: When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical. For wet-surface or submerged water or gasoline repairs, see our J-B Stik or Waterweld product information. "
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
31 Oct 2011 16:27 - 31 Oct 2011 16:27
Just found a bunch of posts on a ifferent forum, with people saying the ethanol gasoline eats through jb weld. :huh:
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
Last edit: 31 Oct 2011 16:27 by clutch.
- clutch
31 Oct 2011 16:29
From Wikipedia:
About alcohol
The JB Weld company advises "DO NOT" use alcohol to clean surfaces.[3] Denatured alcohol (ethanol) acts as a thinner for J-B WELD or epoxy, so it drips more or runs into cracks.[1] However, rubbing alcohol (isopropanol and water) should be avoided as a thinner, because of the larger proportions of water.[1]
About alcohol
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- mark1122
- Keep twisting it
31 Oct 2011 16:38
i can tell u from experiance that JB Weld is NOT gas proof, when submerged. i have tried to use it to repair carb parts and it fails.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- clutch
31 Oct 2011 16:40
ANyone know if neoprene gasket material will hold up against the deathanol?
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
31 Oct 2011 16:49clutch wrote: ANyone know if neoprene gasket material will hold up against the deathanol?
Nope....
I wonder if my buddy that welds could seal it up for me???
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
Last edit: 18 Feb 2013 18:01 by martin_csr.
- clutch
31 Oct 2011 18:01
Yes. I already have the parts, yet I'm having issues with leakage. I don't want to go back to the vacuum petcock if I can stop the leak.
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- clutch
31 Oct 2011 18:13
I've been searching the web for hours, and so far this is the best thing I've found for info...
iqlearningsystems.com/ethanol/downloads/...%20Compatibility.pdf
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
31 Oct 2011 18:14
You shouldn't need any sealer on the gas tank; what are you trying to seal? The petcock (at least on mine) uses an oval rubber O-ring that prevents any leaks. Did you do some homemade mods to the tank? Ed
- Motor Head
31 Oct 2011 18:42
You got one of those Pingel Adapter plates that is flat with the 2 bolts and gasket, right?
So which joint is the problem, plate to tank or petcock to adapter?
