welder
- bearshawk
welder
23 Oct 2011 19:50
hey guys im looking for a good, inexpensive welder to improve my welding skills over the winter. harbor freight sells them... and what was what we had in shop class in highschool, seemed to work fine.
what do you guys have?/recommend
Thanks
Thanks
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
- racer54
Re: welder
23 Oct 2011 20:09
I have welded some at work with a factory rated welder. I bought a Lincolm 135A welder hoping it will be enough to do welding around the homestead but not sure how good it will be welding on a bike. Worried it won;t be big enough to get a good enough heat soak to have a strong weld that I can trust. I would be interested in what some of you guys who have welding experience think of the capacities of these small 110 a/c welders are. I'm sure these home wleders will be fine for aroung the house jobs and crafts, etc. but not sure how good they would be on stuff like welding on bikes, trailers, etc. where a safety issue comes in.
- Nebr_Rex
Re: welder
23 Oct 2011 20:27
Stick with the name brands,Miller,Hobart,Century,Lincoln.
Make sure you can get your consumables,tips,cones,liners,drive wheels,etc..
My 110v has 2 settings,90 and 135 and I run the smallest fluxcore wire that I can find thru it.
It burns a little hotter and more of a job to clean up,but will burn thru the factory welds to get good penitration when needed.
MIG is better on clean metal,fluxcore on the dirty,rust stuff.
If I need something cleaner I have a Miller Sync. Wave 250 for TIG and stick.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- andy9802gt
- If it tastes that good, eat it yourself.
Re: welder
23 Oct 2011 21:13
Any 110v welder should be able to handle up to about 3/16" so welding the frame on your bike, trailer, hell even your truck should be within it's capabilities as long as you use flux core wire and they are better for welding sheet metal since they burn so much cooler than a 220v welder.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- boatdrinks
Re: welder
23 Oct 2011 21:32
Hi bearshawk. I am a salesman in the welding industry. Are you looking for a tig or mig? In my opinion you should go to your nearest welding distributor to purchase a welder. The harbor freight machines as with those found at Lowes and Home Depot are not of the same quality as the equipment you will find at your welding distributor. Additionally if you purchase at a big box store, does anyone there know how to help you if you have a problem? Can they hook you up with a warranty repair center if there is a problem with your new machine? Just a few things to consider before you go out and possibly make a mistake.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
- superbovine
Re: welder
23 Oct 2011 22:09
I use eastwood welders and have had great experiences with them. They aren't as cheap as harbor freight etc ones but they are pretty inexpensive for the quality, and they have great support if you run into any issues, plenty of service parts available etc. Certainly not on par with Millers etc, but great welders none the less.
Just be sure whatever you get if it is a flux core welder it can be upgraded to gas MIG. Welding with gas shielding makes for prettier welds, less clean up, etc. Even if you save a few bucks getting a flux only machine, it would be quite a waste to have to buy a whole new machine when you are ready to sharpen your skills a bit.
- Boostable
Re: welder
23 Oct 2011 22:49
I am currently using a Lincoln SP125-Plus that I am able to use from the shop at the office. It does a very good job, and its pretty adequate for what we are doing on our bikes. Next week im gonna go ahead and pickup a Hobart Handler 140. Once again rated about the same, maybe a little better, but will do everything I need it to do and I can either FCAW or MIG on it down to .023
I primarily FCAW with mine on the bike to support the heavier metal, but if im overly concerned I will multi pass the weld joint.
Im certainly no expert, and others here have much more experience in this area then I.
Here is a comp chart... its on Hobarts website, so take it for what is worth, but a basic comparison none the less.
www.hobartwelders.com/pdf/comparisons/handler140.pdf
Jack
Jack
~Jack
1982 KZ1000 J2 ~ Project (Street Fighter - Project Section)
1976 KZ900 - Daily Rider
- rustys
Re: welder
23 Oct 2011 23:49I love my Hobart Handler 140, I haven't had too much use on heavier gauage metals, but on sheetmetal it is great. Plus, it has the gas option so that really gives me some nice weldsBoostable wrote: I am currently using a Lincoln SP125-Plus that I am able to use from the shop at the office. It does a very good job, and its pretty adequate for what we are doing on our bikes. Next week im gonna go ahead and pickup a Hobart Handler 140. Once again rated about the same, maybe a little better, but will do everything I need it to do and I can either FCAW or MIG on it down to .023
Jack
Rusty
- crappiehuntr
Re: welder
24 Oct 2011 01:33
If its someting that is easily acessable to weld you can put a torch to it and preheat the metal before welding gets alot deeper penetration my neighbor who is a pipe fitter taught me that trick.
1977 KZ1000
1978 KZ650
1976 KZ900 project
1981 KZ550 project
1978 KZ650
1976 KZ900 project
1981 KZ550 project
- boatdrinks
Re: welder
24 Oct 2011 07:40
Where ever you buy on just be sure to ask if the machine is equiped with a gas solenid. If it is not you can only weld with flux cored wire or you will have to find a solenoid kit for it.
Charles
Madison, AL
Madison, AL
- testarossa
Re: welder
24 Oct 2011 08:42
I have a Millermatic 135 that is 110V and it has served me very well for my bike. I like the fact that it has infinitely adjustable amperage and wire feed settings. That makes it easy to fine tune for what ever I'm welding. Also, for doing sheet metal work, it's perfect. Switch to the 0.023" MIG wire and you can weld 22ga without burning holes all the time. If you need to do the heavier stuff, use it with the flux core wire and it can handle 3/16" in one pass. Pre-heating with a propane torch really helps on the thicker stuff.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
Re: welder
24 Oct 2011 13:27
I have a Lincoln 135SP that I used for the majority of the bikes construction. Like testatossas Miller it has infinitely adjustable amperage and wire feed making it easier to find the sweet spot. I recently picked up an import fig/arc welder. After resolving some shipping damage issues, I am very pleased with the machines performance on mild steel, stainless steel, aluminum and titanium. A goodi wouldn't be afraid of a 110v 135amp mig welder not having enough huevos to weld a bike frame though. I'm literally betting my ass on it :laugh:
FRANKEN Z!
