Welding RODS
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
Re: Welding RODS
06 Jan 2011 18:43 - 06 Jan 2011 18:48
#420437
:) PLUMMEN wrote:
hell,i can make it look purty with any kind of rod! :laugh:
i can make it look purty welding flat,vertical up,vertical down and overhead B)
plummen you wanted pictures.....im not into the mines bigger than yours is. this is a prime example of what 6010 and 7018 will do to schedule 40 pipe. the fact that you pmed me about your argument is enough to get me to back off. i dont want to argue. good fortune.
1978 KZ1000A2
Last edit: 06 Jan 2011 18:48 by kz1k.
  • Brown Bear
  • Brown Bear's Avatar Topic Author
Re: Welding RODS
06 Jan 2011 20:42
#420458
tac in place will be mig. as its quick but overall weld i want to do with the TIG i have coming. well its a TIG, ARC and plasma cutter combo. hehe.
  • porchev914
  • porchev914's Avatar
Re: Welding RODS
06 Jan 2011 22:40
#420470
Who did you buy your welder from BB?
FRANKEN Z!
  • TomW
  • TomW's Avatar
  • Keep the blue side up.
Re: Welding RODS
06 Jan 2011 22:51
#420473
I would tack with MIG using ER70-S6. Finish with TIG using ER70-S2.
6010 is used a lot for code welding pipe. It's dirty, penetrates a lot and is difficult to weld with. 7018 is a low hydrogen rod used for structural steel fabrication. It would probably make a good frame weld but stick, aka SMAW, would be very difficult to use on a frame. Wire dia for your MIG and TIG will vary with the wall thickness of the tubing used. .023" would probably be OK for the MIG. 3/32" would probably be a good compromise for the TIG. Maybe 1/8" on the larger tubes. Use type 308 for general purpose on SS. Aluminum I have very little experience with. Ask your welding supplies dealer.
Tom
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
  • keith1
  • keith1's Avatar
Re: Welding RODS
07 Jan 2011 17:09 - 07 Jan 2011 17:14
#420641
kz1k wrote:
6010 for penetration, 7018 for cover pass. the forst 2 numbers are tinsel strenght, the third number is the position, and im not sure what the last number is. but you wont need to know that. JUST DO IT!
not to be argumentative,but i spent 2 years in welding school 30 years ago.....the first 2 numbers are tensile strength in thousands of pounds per square inch...the last two numbers are for flux composition and positions the rod can be used in.....i forget which is which on the last two....i do remember filling in 2inch bevels with a backer and cutting out a strip and stress testing it.....one minute piece of slag left behind and 2 hours of laying down beads gone to shit......:blink:......i would mig everything on a bike frame.....hell, i worked at pathfinder snowplows in high school in the mid-eighties and everything was migged......they held together fine and they take a lot more stress than a kz flexi-flier.......just my .02
Last edit: 07 Jan 2011 17:14 by keith1.
  • kz1k
  • kz1k's Avatar
Re: Welding RODS
07 Jan 2011 17:16
#420642
it doesnt bother me when people call me a "migger"
1978 KZ1000A2
  • Brown Bear
Re: Welding RODS
07 Jan 2011 18:18
#420654
ooook well i guess i will mig for now then but i do need to use the tig on some area. even if it is to make the mig welds look good. lmao
  • porchev914
Re: Welding RODS
07 Jan 2011 23:28
#420685
Tig is absolutely fine, these guys have been talking about stick welding. Who did you get your welder from BB? I got a tig machine from Everlast but I have had some trouble with it and am now waiting for a replacement :angry:
FRANKEN Z!
  • Brown Bear
Re: Welding RODS
11 Jan 2011 15:42
#421540
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem...geName=STRK:MEWNX:IT
this is the one im now getting, i changed it as i realised the tig, arc plasma cutter was only ac. and that aint no good just ac. lol.
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: Welding RODS
11 Jan 2011 16:18
#421546
TIG= very hard to do and even harder to make look pretty if you don't do it all the time. Stick= also hard to do but not quite as difficult as TIG. Great if you want to fix your tractor, not so much on what is basically rolled up sheet metal. MIG= easy to do with minimal practice, probably the best method for this job. Would not use anything over .030 wire and would use a tri-mix gas if you can, they offer better penatration and provide a cleaner weld. Just .02 from me.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • keith1
  • keith1's Avatar
Re: Welding RODS
11 Jan 2011 19:00
#421587
what he said......B)
  • notaduc
  • notaduc's Avatar
Re: Welding RODS
15 Jan 2011 10:14
#422421
Hey folks, I am a professional welder/fabricator, in the motorsports industry, while I have never made a motorcycle frame, I plan to.
Preferred joining methods, TIG, oxy/acetylene welding, fillet brazing, mig. Stick is very difficult to do on thin gauge tubing with good results, for a beginner, I would recommend MIG, no questions, get your machine set perfectly on some scrap tube, get your rhythm down, cut up some of your test pieces to check for defects/penetration.
I am certified on 6g stick pipe and would never consider using it for this sort of application.
1980 (mostly) KZ1000
