Welding RODS
- Brown Bear
Welding RODS
06 Jan 2011 16:51
hi all i really need alot of advise here before i go buying.
i'll be welding hardtail frame tube and so on. mild steel stainless and alliminium.
can you tell me the best types of mild steel to use and on what tupes tube etc..
and so on. as iv found alot on ebay going pretty cheap in bulk amounts but i dont know what types are best for welding what types mild steel grade etc
many thanks
many thanks
- kz1k
- You Cant Fix Stupid!
Re: Welding RODS
06 Jan 2011 17:07
6010 for penetration, 7018 for cover pass. the forst 2 numbers are tinsel strenght, the third number is the position, and im not sure what the last number is. but you wont need to know that. JUST DO IT!
1978 KZ1000A2
- Brown Bear
Re: Welding RODS
06 Jan 2011 17:10Please Log in or Create an account to join the conversation.
- Brown Bear
Re: Welding RODS
06 Jan 2011 17:12
kz1k wrote:
oh very quick penetration.... cover pass??????
- PLUMMEN
Re: Welding RODS
06 Jan 2011 17:26
6010 is for welding rusty fence posts! :laugh: weld it with 7018 and be done with it.or just get a mig welder
check local welding shops for tubing to use,lot cheaper that way.
for welding stainless i like 308-16,works better with a dc machine though.
check with z-torch,he'll know best rod for you to use.
- kz1k
Re: Welding RODS
06 Jan 2011 17:31
PLUMMEN wrote:
a route pass is thr first most important pass. the cover pass is just a lets make it look pretty pass.
i have used these rods fo years welding 2.5" up to 24" pipe.
yes, 7018 will be all you need for this application.
6010 is used for a route pass. 7018 is for a cover pass over the 6010.6010 is for welding rusty fence posts! :laugh: weld it with 7018 and be done with it.or just get a mig welder
1978 KZ1000A2
- PLUMMEN
Re: Welding RODS
06 Jan 2011 17:37
hell,i can make it look purty with any kind of rod! :laugh:
i can make it look purty welding flat,vertical up,vertical down and overhead
- Brown Bear
Re: Welding RODS
06 Jan 2011 17:59 - 06 Jan 2011 18:02
i do have a mig welder aswell. but i want pretty looking welds. plus tig sounds fun. hehe. thanky you all. i will let you know how i get on and yes i will take pics. my 1st time. haha
so the link i post aove they no good?
Last edit: 06 Jan 2011 18:02 by Brown Bear.
- PLUMMEN
Re: Welding RODS
06 Jan 2011 18:03
those frames were mig welded from the factory,pretty hard to make them look much worse than some of those factory welds! :laugh:
- Brown Bear
Re: Welding RODS
06 Jan 2011 18:17
PLUMMEN wrote:
you aoint seen someone i know. bloody hell. he does worse than factory. haha
but those ones showed any good?
- porchev914
Re: Welding RODS
06 Jan 2011 18:36
The link was to tig welding or oxy/acetelyne rod. You would only use that if you have a tig welder or are planning to use a gas welding rig. What welding process were you planning to use?
FRANKEN Z!
- kz1k
Re: Welding RODS
06 Jan 2011 18:39
PLUMMEN wrote:
this is the truth....those frames were mig welded from the factory,pretty hard to make them look much worse than some of those factory welds! :laugh:
1978 KZ1000A2
