Welding RODS
  • Brown Bear
  • Brown Bear's Avatar Topic Author
Welding RODS
06 Jan 2011 16:51
#420404
hi all i really need alot of advise here before i go buying.
i'll be welding hardtail frame tube and so on. mild steel stainless and alliminium.
can you tell me the best types of mild steel to use and on what tupes tube etc..
and so on. as iv found alot on ebay going pretty cheap in bulk amounts but i dont know what types are best for welding what types mild steel grade etc
many thanks
  • kz1k
  • kz1k's Avatar
  • You Cant Fix Stupid!
Re: Welding RODS
06 Jan 2011 17:07
#420410
6010 for penetration, 7018 for cover pass. the forst 2 numbers are tinsel strenght, the third number is the position, and im not sure what the last number is. but you wont need to know that. JUST DO IT!
1978 KZ1000A2
  • Brown Bear
Re: Welding RODS
06 Jan 2011 17:10
#420411
  • Brown Bear
Re: Welding RODS
06 Jan 2011 17:12
#420412
oh very quick penetration.... cover pass??????
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Welding RODS
06 Jan 2011 17:26
#420414
6010 is for welding rusty fence posts! :laugh: weld it with 7018 and be done with it.or just get a mig welder
check local welding shops for tubing to use,lot cheaper that way.
for welding stainless i like 308-16,works better with a dc machine though.
check with z-torch,he'll know best rod for you to use. B)
  • kz1k
  • kz1k's Avatar
Re: Welding RODS
06 Jan 2011 17:31
#420415
6010 is used for a route pass. 7018 is for a cover pass over the 6010.
a route pass is thr first most important pass. the cover pass is just a lets make it look pretty pass.
i have used these rods fo years welding 2.5" up to 24" pipe.
yes, 7018 will be all you need for this application.
1978 KZ1000A2
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Welding RODS
06 Jan 2011 17:37
#420418
hell,i can make it look purty with any kind of rod! :laugh:
i can make it look purty welding flat,vertical up,vertical down and overhead B)
  • Brown Bear
Re: Welding RODS
06 Jan 2011 17:59 - 06 Jan 2011 18:02
#420424
i do have a mig welder aswell. but i want pretty looking welds. plus tig sounds fun. hehe. thanky you all. i will let you know how i get on and yes i will take pics. my 1st time. haha
so the link i post aove they no good?
Last edit: 06 Jan 2011 18:02 by Brown Bear.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Welding RODS
06 Jan 2011 18:03
#420425
those frames were mig welded from the factory,pretty hard to make them look much worse than some of those factory welds! :laugh:
  • Brown Bear
Re: Welding RODS
06 Jan 2011 18:17
#420429
you aoint seen someone i know. bloody hell. he does worse than factory. haha
but those ones showed any good?
  • porchev914
  • porchev914's Avatar
Re: Welding RODS
06 Jan 2011 18:36
#420435
The link was to tig welding or oxy/acetelyne rod. You would only use that if you have a tig welder or are planning to use a gas welding rig. What welding process were you planning to use?
FRANKEN Z!
  • kz1k
  • kz1k's Avatar
Re: Welding RODS
06 Jan 2011 18:39
#420436
this is the truth....
1978 KZ1000A2
