possible?
- wireman
Re: possible?
07 Dec 2006 10:50
why dont you just fab up some kind of ram air system from under front of tank back to stock airbox?:whistle:
- Lorcan
- Speed Loony
Re: possible?
07 Dec 2006 12:40
Sit on the bike backwards...
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- freebyrd24
Re: possible?
07 Dec 2006 12:45
this thread is too funny :laugh:
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Sold:
- 77KZ650
Re: possible?
07 Dec 2006 20:45
its possible to put the head on backwards, and its been done, just time the cams 180 out. if you want to see a bike that has this done to it, and lots more, check out
www.larrymcbride.com
B)
Also check out Allen Millyards bikes, the V-8s made from kz1000's have the rear top end going backwards, so does his V-12 made from kz1300's
Scott
Post edited by: 77KZ650, at: 2006/12/07 23:54
Scott
07 MDP Rookie of the Year
- lunchbox
Re: possible?
08 Dec 2006 00:19
i knew i wasn't completely off my rocker! oh well, too much work, and just not enough interest to actually try it. maybe another project, another time!
- KB02
Re: possible?
08 Dec 2006 05:00
From a stand point of air flow, having the carbs behind the motor has the very same air flow as having them infront of the motor (minus any "ram" effect) as it does with e carbs on the side (Can you say "V-Twin?). Physics is funny that way. t's just a matter of best placment from a legistics stand point as to where everything fit in the frame. However, while it would be possible, it would be easier to just fab up a Ram air duct along the bottom of the tank.
- CoreyClough
- GPz550 Addiction
Re: possible?
08 Dec 2006 05:36
Is this what it's coming to? Have all the possibilities been exhausted with the KZ, and now you're thinking of this? Winter surely has set in early this year on KZR Hasn't it? Set the Jack daniels down, and step away from the keyboard. I wouldn't know what I'd do if I had to go thru winters like some of you do. Maybe I'd be thinking of things like this too. Like the song goes, "It's the most, hungover time, of the year..." :woohoo:
Turn the transmission around so you have 5 speeds in reverse, and then the intakes will be in the front. You'll have to ride like a fork lift with rear steering. I suggest you gear it for low speeds.
Anything's possible when you wish upon a star.
Post edited by: CoreyClough, at: 2006/12/08 08:37
'85 GPz550(ZX550-A2)
- 77KZ650
Re: possible?
08 Dec 2006 07:21
lunchbox wrote:
it would be really cool to see a street bike done up like this, but it would probably be better suited for the drag strip. I think the top feulers used to to something along these lines to get the ram air effect
if you do try it, it would be cool to see an undertail exhaust made. mcbrides is cool where it comes out behind the seat, but think of 4 straight pipes pointing out around the tail light straight back. it would be one of the least restrictive exhausts ever made, hardly any bends. carb/frame tubes might try to occupy the same area, so that may be a challenge, and you may have to rake the front out a bit to get room for a set of pods or stacks.i knew i wasn't completely off my rocker! oh well, too much work, and just not enough interest to actually try it. maybe another project, another time!
- modprod
Re: possible?
08 Dec 2006 09:34
lunchbox wrote:
One of the biggest problems is the location of the stock frame downtubes. This is not a new idea and was done on these motors better than 25 years ago. Terminal Vanlines had done this even before Elmer. Cam timing is done just like a Yamaha XS11 where the motor runs the other direction. Actually this is a good idea in a different frame. You should do it with an air box similar to how the "car boys" do it for the proper "ram effect"
would it be possible to flip the cylinders so that the carbs were in the front? i'm trying to picture all this in my head, it's starting to swell pretty good and hurt:unsure:
- lunchbox
- RetroRiceRocketRider
Re: possible?
09 Dec 2006 09:33
lunchbox wrote:
I'm sorry lunchbox, I wasn't trying to rain on your parade or question your brain-storming.
History has shown us that truely great things can come from letting the mind roam free and think outside of the box.
But to reiterate what I said before, yes, it IS do-able.
But not without some serious fabbing done to the frame, engine, and exhaust/intake systems.
I for one would really be interested in seeing it done, as well as the intricacies involved in the fabbing.
Post edited by: RetroRiceRocketRider, at: 2006/12/09 12:34
man, what the hell did i start?
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- kawadruida
Re: possible?
09 Dec 2006 10:03
With certain engine layouts it should be a much easier task...
I remember an article somewhere about a woodtracker inspired customized Moto Guzzi with the carbs (and velocity stacks) in front and exhausts running from the back. It seems not to be a big problem with Guzzi´s typical transverse V-Twins or a BMW boxer as well.
But it HAS to involve a lot of work with any transverse inline four, involving major frame modifications for sure.
Anyway, you fired up a most interesting thread. Lunchbox!
BTW: Don´t you think that the V12 KZ2300 is plain amazing? I wonder how it sounds, sweeeeeeet and mellow!
