installing a used clutch
  • floridamba
  • floridamba's Avatar Topic Author
03 Dec 2006 15:05
#97090
I've taken an used clutch out of a spare motor that I want to sell. My stocker is slipping badly and this will fit it.
My questions, the spare has been sitting for probably 20 years but was clean and oily when I took it out of the engine. Since these plates are made to go fast and be hot they should be ok.....
Any concerns on using a clutch that's been sitting that long? If it slips also then I'll have to buy one.
I did check the adjustment on the left side cover and it's good. Also checked the cable. I suspect mine slips because the PO probably put some kind of anti-friction coating in the engine. I've since changed the oil and run it for a while.
Tia
  • flht1997
  • flht1997's Avatar
Re: installing a used clutch
03 Dec 2006 15:20
#97104
wht not? really do not have anything to lose. i have done it several times
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
03 Dec 2006 15:40
#97111
With used metal plates I usually scuff them up with a scotchbrite pad to take glaze off. Make sure they are flat.
Check the fiber plates do not have any cracks in them.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • floridamba
03 Dec 2006 16:46
#97146
Sounds great guys, thanks
