- Thank you received: 1
810 option
- agawam
- reborn650
Modifying the case are not a big deal as all you need to do is have a variable speed cordless drill with a couple of aluminum cutting/grinding bits. Just take your time and do test fittings as you go along. It think this took me a couple of hours with a beer break or two thrown in.
If you have any questions on the 810 project send me a U2U and I will do my best to lend you my experience. Let the 700 live to ride another day and rebuild the 650 engine that looks the best.
1977 Kz650 Custom-810 big-bore with lottsa go-fast goodies tucked away inside.
-1998 Jeep TJ Wrangler 4.0...
- agawam
- steell
So unless it's a 1980 block, your choices are going to be limited to 650's with the HyVo cam chain (or some modifications).
- agawam
- steell
As far as cam choice, it really depends on what you are planning to do with the bike.
Post edited by: steell, at: 2006/10/29 00:09
- OnkelB
- Thank you received: 80
..is the hyvo set up less desireable, if so why ?
Actually if you´re rebuilding the entire cam chain setup the Hy-vo setup is more desirable - this setup uses a front and rear plastic slider guide and a rubbing block in the valve cover, these can all be replaced for app. $100 or less. The single roller setup uses a center rubber guide wheel at the cylinder base and 3 idler sprockets - while the rubber wheel is not too costly ($15-20), the guide sprockets are, they´re $110+ a piece for OEM (I´ve seen them as high as $177). You can get pattern idler sprockets for slightly less ($65-80 a piece), but they don´t have the dampening rubber coating that the OEM ones have.
Btw, if you´re going to replace the idler sprockets, the ones used on the 650s and the ones used on the 900/1000s are the same even if they have different part numbers.
Post edited by: OnkelB, at: 2006/10/29 06:55
77 KZ 650 B1, 82 GPz 1100 B2.
- agawam
- agawam
- steell
Look at the difference in the photo posted by Mark Wing in another thread.
Here's the original thread
Post edited by: steell, at: 2006/10/29 20:37
- agawam
- reborn650
I stuck with the roller cam chain set up that came stock in my 1977Kz650 Custom. The research and advice I received from other Kz enthusiasts was to stick with the roller as it spun the revs up quicker than the Hy-Vo. There was no data to back this up, just a gut feeling from the gang.
You will need to split the engine cases to do the enlarging work to have the bottom of the 750 cylinders fit into the top of the 650's cases.
Set your top case in a vise and pick up a couple of aluminum cutting bits for your variable speed drill. I had one bit that was cylindrical with a flat and as well as one that was more egg shaped with a rounded end. Take your time and keep a Sharpie marker handy to mark the areas that need to be trimmed after each test fitting. Go slow with the metal removal as it is impossible to put any back on:)
What type of cams and carbs are you planning on going with? I used my 650 head with Kz750 cams, valves and Gpz springs.
You will have fun with the 810.
If you have any questions fire away.
1977 Kz650 Custom - 810 big-bore, WG Mikuni 28's and lottsa go-fast goodies tucked away inside.
