why is my bike pissing oil?!
16 Sep 2006 15:13 #77249 by cary
why is my bike pissing oil?! was created by cary
can't keep this thing from dumping dino juice all over the top of the transmission (see pics). It's leaking like a sieve, enough that I actually am afraid to ride, lest I run too low.
Just noticed it today. Am running 20w50 in a stock 998cc '82 KZ1000. Normally it leaks pretty bad from the cam caps, however, it isn't today for some reason. It's pooling up really quickly on the bottom end. i can't tell where it's coming from. The oil is NOT coming from the crankcase breather, as I have a hose routing this over the chain. Also, the breather is NOT clogged, as you can feel it pushing out air at idle. The bike was dangerously low on oil when I checked it today (filled it up w/ a quart of 10w40), and was making clattering noises. It is also getting harder to start when hot. The oil was changed about 2 weeks ago. Can anyone help?
16 Sep 2006 15:21 #77254 by steell
Replied by steell on topic why is my bike pissing oil?!
Clean it off real well, start the bike and look for the leak, is the only thing I can think of.
16 Sep 2006 15:24 #77256 by cary
Replied by cary on topic why is my bike pissing oil?!
16 Sep 2006 15:24 #77257 by cary
16 Sep 2006 15:25 #77258 by cary
16 Sep 2006 15:27 #77260 by cary
is there any way besides the breather being clogged that can cause the bottom end to push too much oil pressure?
16 Sep 2006 16:25 #77277 by ten6
Replied by ten6 on topic why is my bike pissing oil?!
Last time that happened to me it was coming from the cam chain tensioner gasket (or lack thereof) when the rpm's came up a bit. Check there...i'll bet you strike oil...:P
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
16 Sep 2006 17:11 #77288 by Nothreat
Replied by Nothreat on topic why is my bike pissing oil?!
"Last time that happened to me it was coming from the cam chain tensioner gasket (or lack thereof) when the rpm's came up a bit. Check there...i'll bet you strike oil..."
I had exactly the same problem - new gasket and some permatex cleared it right up...
17 Sep 2006 03:25 #77352 by 74cb750
Replied by 74cb750 on topic why is my bike pissing oil?!
aboy does this look familiar...mine was coming from the cam tensioner also.
peace,
michel
It is still to cold to ride!
17 Sep 2006 08:36 #77393 by cary
thanks for the insight guys... I've never been into one of these motors deeper than the valve cover, what is involved in changing the cam tensioner gasket? can i do this w/o tearing the top end off?
17 Sep 2006 09:07 #77394 by ten6
It is very simple. You probably would have to take off the carbs and then the two bolts that hold the tensioner on. It is mounted to the outside of the engine block just below the center of the carbs. Sometimes you can get to the bolts without removing the carbs but not likely. You have to follow the proper procedures for reinstallation of the tensioner but I will let someone else tackle that. Also, you MUST buy a service manual for this machine. It will save lots of headaches and will teach you loads of stuff. Good luck.;)
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
17 Sep 2006 12:45 #77434 by wiredgeorge
Replied by wiredgeorge on topic why is my bike pissing oil?!
Four reasons for oil where you are seeing it.
1. base gasket on cylinder head leaking
2. oil pipe where the oil pressure sensor is located leaking (two orings under the pipe)
3. can chain tensioner gasket leaking (remove two bolts, scrape old gasket/replace with new and readjust tension)
4. low profile breather not sealing.
I had one of the low profile breathers and it would NOT seal and leaked oil all over the place just in the location yours is leaking. I have also had the other three things happen over the years but I if that is an aftermarket breather cover, I would look there first.
