why is my bike pissing oil?!
17 Sep 2006 15:13 #77461 by donthekawguy
Replied by donthekawguy on topic why is my bike pissing oil?!
I had a cam cover leak like that. You said you have had it off so you might want to check there.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
18 Sep 2006 03:59 #77595 by cary
Replied by cary on topic why is my bike pissing oil?!
everything down there looks stock, so I'll go with the cam tensioner theory for now. the only spray deodorant i have at the house was clear, so i'll have to wait tilli go by the store to confirm the location of the leak.... where does one get a gasket for a cam chain tensioner, I didn't see one over at jeff's?
  • ambergrismooon
  • Visitor
18 Sep 2006 05:05 #77607 by ambergrismooon
Replied by ambergrismooon on topic why is my bike pissing oil?!
Not to throw gas on a fire but it looks like your center carbs have been leaking too. The bowl looks the color of the oil.
18 Sep 2006 07:37 #77630 by kawtoy
Replied by kawtoy on topic why is my bike pissing oil?!
I think I have a cam tensioner gasket. Mine should be the same as yours. i will check when I get home and send it off to you if I have it. Also if you wanna swing by this weekend I should have my new Colortune in. That is the spark plug with the crystal bottom so you can see into the combustion chamber and set each carb so that the mixture is just right. I can't wait to play with it. You are welcome to come by and see how it works on your bike. Later
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
18 Sep 2006 09:11 #77639 by cary
gris -- that gas leak's not a problem, it's a feature! how else will I obtain that elusive petrochemical aroma that kzriders are famous for and the ladies love?
18 Sep 2006 11:48 #77661 by cary
It's raining in Tennessee today, so no test rides to check the source of the oil, but I did look on kawasaki.com at the blowup of my tensioner, and it appears that there is only an o-ring there, can
I replace this with any old o-ring that fits?
18 Sep 2006 15:05 #77694 by Mandrake
Replied by Mandrake on topic why is my bike pissing oil?!
I just replaced the two O-Rings in my oil-pressure switch and it took care of the problem on my 88 KZ1000J. Looks very similar to what you are experiencing. Worth a try - the O-Rings run about $.90 each
Mandrake
