Help....I cant change gear.....
  • steell
  • steell's Avatar
Re: Help....I cant change gear.....
11 Sep 2006 15:40
#75953
On some KZ's, (I don't know if this applies to yours) it's possible to install the shift lever in a position where it will hit the case when you try to upshift and prevent the trans from shifting past neutral.
That's why I asked, figured it was worth checking.
Post edited by: steell, at: 2006/09/11 18:41
  • CHiPs
  • CHiPs's Avatar Topic Author
11 Sep 2006 16:56
#75969
B) Thanks for your input guys........I'll have another crack at it this week-end, I;ll let you know what the outcome is;)
  • CHiPs
18 Sep 2006 15:22
#77700
Hi guys....
had another go at the "gear-change" problem..........turns out "Steell" hit the nail right on the head when suggesting,,,,
"On some KZ's its possible to install the shift lever in a position where it will hit the case when you try to upshift and this will prevent the trans from shifting past neutral":woohoo: :woohoo: , ....
my friend suddenly remembered that he DID remove the gear linkage for some reason (he cant remember what for!),
and obviousley put it back wrong:blush: :blush: ,
many thanks one again for all your help....mucho appreaciated..........I feel such a fool now :silly:
Post edited by: CHiPs, at: 2006/09/18 18:23
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
18 Sep 2006 15:43
#77704
And the prize goes out to Stevie ELL!!:woohoo:
So what did You win,You ask?...a coupon for a free cup-o-joe at the Golden-Arches!
Way to go Steell!!:woohoo: B)
1977 KZ1000 A-1
