Help....I cant change gear.....
  • CHiPs
  • CHiPs's Avatar Topic Author
10 Sep 2006 15:20
#75710
Hi guys,
My apologies if this question has been asked/resolved allready..
I have a police1000 C4.1981?
The bike has been off the road for 9 months while i waited for a friend to replace various gaskets on the engine (nine months for that you ask? its a long story:blink: )
anyway, the gear selection worked fine when i parked it up , and when I picked it up yesterday, I found it will only go into 1st gear........I cant select any others?
I'm not very mechanically-minded (i just ride'em) any thoughts?...
Thanks in advance,
Daviet
  • hwms
  • hwms's Avatar
Re: Help....I cant change gear.....
10 Sep 2006 15:22
#75711
Countershaft (sprocket) has to be turning to shift to second and higher.
If you can not shift into neutral or any othe gear that may be a different story.
Post edited by: hwms, at: 2006/09/10 18:23
  • CHiPs
10 Sep 2006 15:31
#75714
with some difficulty it will return to neutral...but it will not select 2nd or higher..
has this been caused by the bike lying idle for so long,or just an unfortunate coincidence?,
  • OnkelB
  • OnkelB's Avatar
10 Sep 2006 15:50
#75717
As Harry says the output shaft needs to rotate to select 2nd gear and above - that means the bike has to be rolling, engine running isn´t enough.
Here´s a link to a thread with some background info on the "positive neutral finder" and a pic of how it looks, at least on a 650:
Positive neutral finder
77 KZ 650 B1, 82 GPz 1100 B2.
  • CHiPs
10 Sep 2006 16:02
#75719
I discovered the problem when i tried to ride it from my friends house........engine running selected first...pulled away...pulled the clutch in to select 2nd......no way was it changing up,
I'm lost I'm afraid:blush:
  • OnkelB
  • OnkelB's Avatar
10 Sep 2006 16:22
#75727
Aw dang, sorry to hear that. I´m not really familiar with the big engines so I´ll leave the advice to someone who knows more than me, but it could just be a problem with the change mechanism springs/shift drum pins - if so it can be fixed from the outside, the mechanism can be accessed through the transmission cover. Did your friend change the gasket for the transmission cover too?
  • steell
  • steell's Avatar
10 Sep 2006 17:20
#75757
When the bike is running and you put it in first gear, does it try to pull away while you have the clutch pulled in, or not running and you put it in first gear and try to push it with the clutch pulled in, does it push real hard like the clutch is still engaged?
  • CHiPs
10 Sep 2006 22:51
#75819
Hi,
to answer your questions...
engine running,1st gear, clutch in,bike will not move(if on centre-stand ,clutch in,rear wheel spins slowly)
engine not running,1st gear,clutch in, bike moves fairly freely.
  • steell
  • steell's Avatar
11 Sep 2006 03:56
#75833
That rules out the clutch as the problem.
What gaskets were replaced? Were the cases split?
Does the shift lever hit the case when you try to shift up?
Post edited by: steell, at: 2006/09/11 06:57
  • btchalice
  • btchalice's Avatar
11 Sep 2006 04:56
#75838
sounds like something bent where the shifter meets the drum. its not hard to get to on the big bikes. you have to remove the shifter and probably the foot peg, then the sprocket cover, the chain and sprocket. then i think there are 6 bolts that hold the inner cover where the problem should be. i need to swap mine out if i can get to it later today ill take pics
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • OnkelB
  • OnkelB's Avatar
11 Sep 2006 07:42
#75858
My thoughts exactly - here´s a pic of a 650 engine with the transmission cover removed, the 1000 should be very similar:
1 is the shift shaft where your shifting lever sits, 2 is the shift mechanism arm that rotates the shift drum, 3 is the overshift limiter, 4 is the shift drum, 5 is the return spring and 6 is the output shaft. Sounds like either the pawl spring (in the circle) came off or broke, the return spring came off or broke or the shift mechanism arm got bent. As Terry says it´s not too hard to get to, can be accessed with the engine in the frame, unlike internal damage to the transmission, so let´s hope we´re right.
Post edited by: OnkelB, at: 2006/09/11 10:43
Post edited by: OnkelB, at: 2006/09/11 10:46
  • CHiPs
11 Sep 2006 12:42
#75914
Does the shift lever hit the case when you try to shift up?<br><br>Post edited by: steell, at: 2006/09/11 06:57
H'mmmm...........yes to the shift lever hitting the case!!....any help ??
if i can post a pic you can see it was just everything abouve the cases that were split.
