To helicoil or not to helicoil...(cam caps)
- wireman
Re: Timesert (cam caps)
23 May 2011 03:47
did you put any lube on threads before installing bolts?
personally i like to heli-coil all the cam cap bolt holes from word go and install new bolts at same time
- KZ250LTD
Last edit: 13 Feb 2012 18:30 by KZ250LTD.
- wireman
23 May 2011 04:01
the guy who used to wrench on my back hoes always said time-serts were the hot ticket,but i dont remember ever installing one myself.
i normally have machine shop do the heli-coils in cylinder heads for me,that way if they jack it up installing them they get to fix it :laugh:
- osage
Re: To helicoil or not to helicoil...(cam caps)
23 May 2011 05:40
KZ250LTD thanks for bumping this. I was putting my cams back in the other day and stopped to convert the in.lbs to ft.lbs but had not got back to it yet. I will be using the lower value now.
1976 KZ750B1
1982 KZ750H3
1982 KZ750H3
