To helicoil or not to helicoil...(cam caps)
  • sm0kinace
  • sm0kinace's Avatar
Re: To helicoil or not to helicoil...(cam caps)
23 Oct 2010 06:10
#408419
larrycavan wrote:
Get yourself a tube of this. Poke every 6mm bolt in the end of the tube to coat the threads before you install it. Works like a charm. Coat at least 50% of the threaded length.
I use this stuff every day and don't strip out bolt holes. Also works nice for cam bearing insert lube.
What do you end up torquing to with that stuff? Aren't the standard torque values for clean, dry threads?
1978 KZ650
Ichyta, KS
23 Oct 2010 06:23
#408426
Before reinstalling the cam cap bolts, it's imo important to first assure that the thread holes are clean, meaning basically not containing any excess oil or other foreign material.
May just apply air pressure from a blow gun, or maybe apply a short squirt of starter fluid, carb or brake cleaner from a spray can.
As noted, lightly lube bolt treads before reassembly.
Good Fortune! :)
  • RonKZ650
  • RonKZ650's Avatar
23 Oct 2010 07:44
#408447
John T wrote:
RonKZ650 wrote:
Exhausts will strip every time if you go too far.
Exhaust studs? or the nuts holding the collars...?
I never put a torque wrench on them... just tight'n by hand... then usually crank the nuts down a tad more... after the engine gets hot..
another thought... instead of oil or grease on the threads, anyone use blue loctite?
For some reason the 6mm bolts that hold the cam caps on the exhaust cam will strip, but never the bolts on the intake cam although using the exact same torque specs. At least that's been my experience. I just don't over tighten any more and have no more problems. You can get that "iffy" feeling at 5 ft-lb. I stop there in that case. No need for loctite. These bolts can't work loose even if they are torqued to only 2 ft-lb because by the constant pressure from the camshaft they can't work loose. Guys have claimed the bolts have worked loose, but I think they are mistaken.
  • larrycavan
  • larrycavan's Avatar
23 Oct 2010 07:48
#408448
Standard torque values. And, as Patton added....clean out the bolt holes.
  • otakar
  • otakar's Avatar
23 Oct 2010 07:51
#408449
I don't know why, but those are the only bolts on the whole bike that no matter what I tighten to, always give me the Heeby-Jeebys when I tighten them. For some reason they always make e nervous. I think just the idea of tightening something critical into aluminum threads, that makes it feel funny. This is why I think I will feel better when i put steel Heli-coils into those holes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • gpzman2000
  • gpzman2000's Avatar
23 Oct 2010 20:48
#408647
Here's a thought...and a bit off topic.... ( apologies in advance )..
Since the KZ based motors are so incrediby durable, why did Kawasaki drop the entire line of KZ based motors ? or am I mistaken here ? I think the Zephyr 750 was continued in the early 1990's ?
23 Oct 2010 21:12
#408651
Huh? The good old air cooled KZ1000 was still produced at least as late as 2005. Check out model KZ1000-P24. They were so reliable the cops were still using them, and that's not light duty. Ed
23 Oct 2010 21:13
#408652
One reason is that water cooling offers performance advantages.
Earlier air-cooled Kaw cop bikes, model history:
Click > en.wikipedia.org/wiki/Kawasaki_police_motorcycles
Latest Kaw cop bike -- water cooled Connie:
Kawasaki 1400GTR, also known as the Concours 14 or ZG1400
Click > en.wikipedia.org/wiki/Kawasaki_1400GTR
Good Fortune! :)
  • larrycavan
24 Oct 2010 06:49
#408694
Patton,
Cool link on the copcycles :)
Anybody know which cities have police departments using Kawasakis ?
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
24 Oct 2010 07:01
#408697
Houston, still (saw several last year)...although they are being phased out I suspect. Around here, many of the local police departments give allowances which let patrol officers buy their own bikes and convert them to police duty....so you see police Hondas, HD, ZX14s, BMWs, Motor Guzzis, etc.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Kraz1
  • Kraz1's Avatar
Re: Timesert (cam caps)
25 Oct 2010 21:40
#409106
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
23 May 2011 03:43 - 13 Feb 2012 18:30
#452963
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 18:30 by KZ250LTD.
