Anyone only using kickstart?
- Torch
06 Aug 2006 22:56
I've actually toyed with the idea of only using the kickstart on my bike and i was wondering if anyone else is doing this on a street bike? Do these bikes have the tendancies of older Harley's to just about throw you over the handlebars if you get sudden pressure buildup in the cylinders from a partial start?
I've tried using mine and found that its really pretty easy to kick over, even though i couldn't get it to start because my carbs were screwed. My buddies 250 quad is harder to kick start than this bike is. Im more than likely going to leave the starter on the bike until i see how its going to go for a while using the kick start only. Then take it off later down the road.
- Sandy
- Fly High,Tony
Re: Anyone only using kickstart?
06 Aug 2006 23:02
I still have Mine on the bike...don't use it,except when I forget to turn off my ignition,and My battery goes dead...DOH!
I get quite a few People commenting on it though...Some can't believe that Anyone makes a motorcycle WITH a kickstarter!...thinking that it's a newer bike...lol.
1977 KZ1000 A-1
- Torch
06 Aug 2006 23:07
Sandy wrote:
Yup, i even had a die hard Harley guy that couldn't believe they put a kickstart on a Kaw. Then he griped and moaned about how he wished he had one :laugh:
- timber
06 Aug 2006 23:21
yep last summer i used kick only. my starter seized up and wouldn't turn over. i took it out. i kicked it all the time. it was easy enough. i got a new starter from a parts bike earlier this year so i put one back in. i still kick start mine most of the time. people do give ya looks when ya kick it over and crack the throttle to make it rap a little on start up.
- Torch
06 Aug 2006 23:37
I do believe if i decide to do kick only, a new kicker pedal is going to be in order. That little thin kick pad is rough to keep your foot on if you have to kick it over several times. One of the old Harley bicycle pedal type kickers would be alot easier to keep your foot on. Not to mention it would look old school like crazy.
- dutchz
07 Aug 2006 00:17
Kick only here... Gotta bump it once in a while too like after carb work or the like. My bike kicks easy tho. 1-2 kicks usually does it. Unless there's hot chicks watching, then it goes to default (sittin still lookin purdy)haha.
1974 Kawasaki Z1
Stock front hub and rear axle.
- steell
07 Aug 2006 03:48
Last year I put a 78 model right control pod on my 80 750 twin so it would have an on/off switch for the lights, the starter button wouldn't work so I took the pod apart and fixed it. The next day the starter quit working again, been kickstarting it ever since
When I actually do need the starter (like after being parked all winter) I just pop off the sidecover and short across the solonoid
Someday I'll get another "rountuit" and fix it again.
- Fourtoes
07 Aug 2006 04:19
Use the kick start 99% of the time. Starts first kick mostly never needed to get to a third kick.
Rarely use the electronic starter. Theres something self satisfying about kick starting my bike. A great start to the day!
- ronjones
07 Aug 2006 05:51
When my bike was up and running, I seldom used the electric start, and I expect to mostly use the kickstart when I breathe life into it again. I can't believe that they are making bikes w/o one. I'm not even sure if it's really a motorcycle if it doesn't have a kickstart. (ok, I'm an old-fart):whistle:
- georgeha
07 Aug 2006 06:33
I try to start my bike with my kickstarter first, since the starter clutch tends to loosen. If I couldn't get it on the third or fourth try, then comes the electric start.
- ltdrider
07 Aug 2006 06:43
I mostly use the kicker.
When it's cold, I kick it 4 times with the choke on, and the ignition off. Then I turn on the switch, and she always lights off after one or two kicks. When its warm, it always starts on the first kick.
I reserve my electric starter for when I occaisionally stall at the traffic light
:blush: and need a quick re-start.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- loudhvx
07 Aug 2006 09:59
My next bike will be bumpstart only.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
