Exhaust crossover pipe on KZ1000J
29 Jul 2006 18:33 #65752 by floridamba
Exhaust crossover pipe on KZ1000J was created by floridamba
I've got an 82 1000 LTD and it has a set of J-model pipes on it. The PO took off the crossover and plugged the crossover connections with freeze plugs. Does this affect performance? Should I put the crossover back on and remove the freeze plugs?
If I put it back on I need the gaskets for the pipe.
thanks for your help.
