Clutch starter
- Maxbou92
Clutch starter
20 Aug 2026 16:07
Hello Guys, I noticed for the first time when engine is really hot my clutch starter begins to slip.. can I buy some rollers and springs or Its better to purchase on Ebay « Vinse clutch starter from Poland » ?! Do the gears need to be changed at the same time?! Thank youu
Kz750e 1980
- Warren3200gt
Re: Clutch starter
21 Aug 2026 02:16
Waste of time, money and effort putting just new springs and rollers in unless you have some desire to do it again properly within a year.
also check your starter gear for ridge wear.
- hugo
- '92 Zephyr 750
Re: Clutch starter
21 Aug 2026 02:19 - 21 Aug 2026 02:29
Yes, you can purchase only springs and rollers,....but removing and installing the starter clutch is a lot,...and I mean a lot of work.,....exhaust, oil pan, whole tranny clutch, oil pump, secondary shaft,...all have to come out to get to it.,.....and don't get me started with proper tools needed.
....and is not only the springs and rollers may degrade, the inner and outer races could develop microscopic cracks, or wear, no visible to naked eye.,....you don't want to do this again anytime soon, thus is better to replace with a whole brand new starter clutch, if you can get it.
.....and by the way, on secondary shaft there is also a cushy drive.,.....rubber slices.......I'd plan on changing that,......they get hard and compressed.
Last edit: 21 Aug 2026 02:29 by hugo.
The following user(s) said Thank You: Nessism, Wookie58
- Maxbou92
Re: Clutch starter
21 Aug 2026 03:12
Thank youu!! I will order new one. And what size are the seal?! Can I find them on Partzilla?!
Kz750e 1980
Re: Clutch starter
21 Aug 2026 03:17
You may find the below link useful as there is a lot of information about this repair and will probably answer any questions you have
z750L: Repair starter clutch - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
The following user(s) said Thank You: hugo, ThatGPzGuy, Maxbou92
