Valve shims
  • rickysnicker
  • rickysnicker's Avatar Topic Author
Valve shims
12 Mar 2026 06:42
#922153
After searching I cannot seem to find the answer.  I'm checking the valve adjustment.  I have the Motion Pro tool, the lever and metal tool with the semi circle.  I have that placed under the cam, and off the shim, but cannot get the shim out,  I can spin it, so I know I do not have the tool on the shim.  What's the trick for getting the shim out?  I've tried a small magnet, with no luck.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Valve shims
12 Mar 2026 06:58
#922155
There is a "cut out" in the rim of the bucket, you should be able to "pop" them from there with a sharp pick - in the VW world we had special pliers that reached around the cam and fitted in the cut-outs of the bucket
The following user(s) said Thank You: MFP-Joe, sf4t7, rickysnicker
  • sf4t7
  • sf4t7's Avatar
Re: Valve shims
12 Mar 2026 08:32
#922156
To add to Wookie's answer: when you insert the holding tool on the edge of the bucket, verify that the notch in the bucket is lined up with a spot that's accessible for the hook tool and you'll be able to "pry" the shim out.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: MFP-Joe, rickysnicker
  • rickysnicker
Re: Valve shims
12 Mar 2026 09:24
#922161
Cheers guys!
  • rickysnicker
Re: Valve shims
22 Mar 2026 07:02
#922456
Does anyone else ever have the same thought, "Why can't things go right sometimes, or at least once?"  I got my new shims and installed them.  Apparently my measurements were off and a couple of the clearances are still tight, with the new shims.  Now, the new shims are so snug I cannot pop them out to change them.  It seems sometimes I just cannot win.....
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
Re: Valve shims
22 Mar 2026 07:43 - 22 Mar 2026 07:47
#922458
Hi Ricky,
I don't understand your issue. The different thickness of shims isn't something that affects the installation and removal of the shims.
As sf4t7 said you should rotate the valve bucket so that the notch faces to the other cam before you turn the cam to depress the valve. If the bucket rotates as the cam lobe comes down you may have to play with it until you manage to depress the valve and still have the notch in the bucket in an accessible location.
The shims are always stuck in place because the engine oil has filled the spaces around the shim. As Wookie58 said a sharp pick will lift the shim if you insert it through that notch in the bucket.
Hope this helps.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 22 Mar 2026 07:47 by KZQ.
The following user(s) said Thank You: sf4t7, rickysnicker
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Valve shims
22 Mar 2026 09:12
#922462
Though frustrating sometimes, persistence pays off in the long run.
When my Kawasaki adventure started in y2k, several options were available for service where I live.
Today one option remains, and will, til I can use a tool no longer.
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: rickysnicker
  • rickysnicker
Re: Valve shims
22 Mar 2026 10:36
#922465
Yes, I have rotated the so the notch is in the front and accessible.  I put the new shim in and now cannot remove it, even with using a pick tool.  Yeah, I'm just frustrated and a bit grumpy.  Nothing ever seems to be as easy as what it should be.  I'm considering using a heat gun to heat up around the shim to see if that will allow it to pop out.
  • rickysnicker
Re: Valve shims
22 Mar 2026 10:37
#922466
Daveo,
I understand that.  That's why I am trying to do this myself.  I have adjusted valves on other bikes, but they have never been this difficult to remove.
  • Kofla
  • Kofla's Avatar
Re: Valve shims
22 Mar 2026 11:04
#922467
I understand your frustration, but shims removal should not be difficult.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
  • rickysnicker
Re: Valve shims
22 Mar 2026 11:45
#922470
I agree, it should not be.  I'm getting to the point where it would almost be easier to remove the camshafts so that I would not have to do battle with them as well.
  • Cra-z1
  • Cra-z1's Avatar
Re: Valve shims
22 Mar 2026 12:14
#922471
If you can pop the shim up and it will not  come out more than likely the bucket is not down far enough to allow the shim to be removed. I personally use the Kawasaki tool but you do need to careful on which way to turn the cams. Im assuming you have a z1900?
