Break-in Oil?
- daveo
Break-in Oil?
30 Dec 2025 09:52 - 30 Dec 2025 09:56
With new piston rings and freshly honed cylinders, what oil should be used during the break-in process, and for how long?
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 30 Dec 2025 09:56 by daveo.
- zed1015
Re: Break-in Oil?
30 Dec 2025 10:30
I just use the oil that it will be run in daily (usually 10/40 semi)..
I also don't limit revs verses mileage.
Just ride the bike as normal without over revving or cruising at a constant rpm and use plenty of engine braking to push the rings into the bores.
The following user(s) said Thank You: ThatGPzGuy, Nessism, daveo, Wookie58
- daveo
Re: Break-in Oil?
30 Dec 2025 11:07I just use the oil that it will be run in daily (usually 10/40 semi)..
Is Rotella T4 15W-40 ok for break-in?
I followed that procedure for my rebuild last Spring, but with Rotella T4...the same oil I used for many years before switching to T6 synthetic during the Summer.
Re: Break-in Oil?
30 Dec 2025 11:43
Hey Dave,
Considering the extreme level of your detail mindedness, and considerable spending to make sure your bike is the "best it can be", I'd go big, and spend the bucks necessary to put the best oil available into your engine.
I'd go with something like this oil from Driven... www.drivenracingoil.com/products/br40-co...-10w-40-break-in-oil
Load the rings a reasonable amount from the start, but don't thrash the engine. Firm, but not hard. Keep rpm down to 75% for a few hundred miles, then increase.
Longer term, use something like M1 10W-40 motorcycle oil. This stuff is better than Brotella. Don't take me wrong, I run Rotella, but my engine is not near the level yours is. You spent big, so don't cheap out on the oil.
- daveo
Re: Break-in Oil?
30 Dec 2025 16:50 - 30 Dec 2025 16:51
My primary concern is having the rings bed-in properly, and that the metal shavings get carried away efficiently to the oil filter.
See:
Proper Motorcycle Engine Break-In After Rebuild | Wiseco share.google/ALFaU1eNkxIiqlvCU
Wiseco recommends applying assembly lube as follows:
6. Then before assembly, use plenty of assembly lube on the cylinder and the piston. Don’t forget to lube the piston pin and bearing along with the rings.
My assembly last Spring only had assy lube applied to the wrist pins, cam lobes and bearings....and engine oil was poured all over the lobes and buckets before the cam cover was installed.
See:
Last edit: 30 Dec 2025 16:51 by daveo.
- StreetfighterKz
Re: Break-in Oil?
30 Dec 2025 17:00
I’m not an “engine master” but I’ve never heard of assembly lube on the pistons and cylinder walls. I’ve only wiped down the walls with clean, lint-free towels until they’re clean. Then used appropriate motorcycle specific oil to lube the cylinder and piston/rings.
Just my 2¢.
Later, Doug
Just my 2¢.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Nessism, daveo
Re: Break-in Oil?
30 Dec 2025 18:07Agree. No assembly lube on fresh honed cylinder bore or on rings. Yes, on the piston pin.I’m not an “engine master” but I’ve never heard of assembly lube on the pistons and cylinder walls. I’ve only wiped down the walls with clean, lint-free towels until they’re clean. Then used appropriate motorcycle specific oil to lube the cylinder and piston/rings.
Just my 2¢.
Later, Doug
The following user(s) said Thank You: StreetfighterKz, daveo, sf4t7
Re: Break-in Oil?
30 Dec 2025 18:23
Agreeing with above
Also 2 items
I apply automatic transmission fluid to the cylinder walls and rings (Just coat them , don't go crazy )
I change the oil and filter after the first 100 miles then motor is good to go
As mentioned above don't keep RPM steady for long , keep revs moving up and down
Also 2 items
The following user(s) said Thank You: StreetfighterKz, daveo, Vinsky
- Vinsky
Re: Break-in Oil?
30 Dec 2025 20:52 - 30 Dec 2025 21:02
Here's a blast from the past. MTC Engineering was one of the first companies to produce piston kits for the four cylinder bikes.
Vinsky
Last edit: 30 Dec 2025 21:02 by Vinsky. Reason: typos
The following user(s) said Thank You: daveo, sf4t7
Re: Break-in Oil?
31 Dec 2025 02:11
I use a wipe of the bore with an oily rag, oil on the pins and "graphogen" assembly lube on the skirts (below the rings)
- MFP-Joe
Re: Break-in Oil?
31 Dec 2025 03:26
All the years, i´ve used only 20W50 Motoroil by assembling Pistons, to cylinderwall, on rings carefully,, some ittle squirts between the gap of the rods to crankshaft, piston bolts, and while further assembling on all neccessary bearing and movement points, ( tappets in head, upper valve stems, cam bearings and oil channels)
With that, i`ve never had any problems while break in phase...or after this, ...only the normal wear in the following miles and years..
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
Z1000 A2 1977
Greetings, Joe
- slmjim+Z1BEBE
Re: Break-in Oil?
31 Dec 2025 04:11
For stock 900 / 1000 air-cooled motors:
Assembly lube & Ridin' technique during break-in are well covered above.
Any quality 10w-40 non-"Energy Conserving" straight dino motor oil. Change it & filter after ~500 mi. or less.
We already know that oil flow volume is important in these motors. Many off-brand aftermarket cartridge oil filters intended for use in air-cooled 900 / 1000 motors, don't have sufficient perforations (flow area) in their inner & outer metal sleeves to allow maximum oil flow volume. The OEM Kawasaki oil filter is our gold standard to evaluate perforations / flow area. If we come into possession of aftermarket filters in a parts lot that appear to have insufficient perforations in the sleeves, we just toss them & don't even offer them for sale at swap meets.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
