Cylinder 3 hot, other 3 not.
- kanexx
10 Sep 2025 19:34
Ok so I did the whole valve clearance and now all are within spec. I got new plug wires , plugs gapped them. Now it doesn't seem to run right. Starts fine idles but sure dont sound the same. Carbs are synced pilots are clean. Timing light is good on all but cylinder 2 and cylinder 3 runs hotter than other 3 . ...? The F dont even show up . 3 is a bit shaky on the F mark 1 and 4 are clear. Not sure what i did. Anybody got any answers or ideas would be greatly appreciated. Thanks. 82 kz 750h3
Kane
Kane
Re: Cylinder 3 hot, other 3 not.
11 Sep 2025 05:07
Are the coils connected to the correct plugs? One coil fires 1 & 4, while the other fires 2 & 3.
11 Sep 2025 05:12
11 Sep 2025 05:14
Here is a copy of the factory service manual, just in case you do not already have one.
www.kzrider.com/filebase-alias?task=down...id=1266&catid=17&m=0
- Nerdy
11 Sep 2025 19:37
I read the topic and for a second thought you had a KZ1300
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- kanexx
11 Sep 2025 21:33
Yes . It dont matter top or bottom as long as clutch side is 2 and 3 and throttle is 1 and 4 correct? How bout the primary and secondary wires, I know g and r left and b and r right.
- kanexx
11 Sep 2025 21:36
Beyond the coils I am putting the old ones back on, I replaced with new oe coils then the problem started.
- kanexx
11 Sep 2025 21:48
Beyond the coils I am putting the old ones back on, I replaced with new oe coils then the problem started. So I have valve cover off again, I had it set on t mark and not lined up exactly parallel with each mark as you can see in photo. I am good on my number of links for sure.
12 Sep 2025 05:17 - 12 Sep 2025 05:19Either coil can do either set of cylinders. What matters is the wiring. Assuming (dangerous) that everythinh around the advancer at the end of the crank is set up according th the factory, the green and red wires go to the coil that is connected to 2 & 3. The black and red go to the 1 & 4 coil.Yes . It dont matter top or bottom as long as clutch side is 2 and 3 and throttle is 1 and 4 correct? How bout the primary and secondary wires, I know g and r left and b and r right.
Has any part of the timing mechanism been taken apart? If so, be certain everything is in the right spot,.
Last edit: 12 Sep 2025 05:19 by TexasKZ.
12 Sep 2025 05:33
Why is the bolt on the exhaust cam in the square hole?
12 Sep 2025 05:38
Looks like the cam sprockets are installed incorrectly. The intake cam sprocket should be installed with the bolts in the square holes and the exhaust sprocket with 5e bolts in the round holes.
- kanexx
12 Sep 2025 07:01
That i have not touched , I have just done valve clearance in which I have not touched those bolts. I will look in my manual, I see you are looking at kz1000, would it be the same as kz750
