Timing Chain
  • Billeuze
  • Billeuze's Avatar
Re: Timing Chain
18 Mar 2025 23:19
#910216
Absolutely make sure the tensioner is correctly tensioned. I missed that somehow once after putting the top end back together. I made it 20 or thirty miles. Chewed up pieces of chain tensioner shoe all through the bottom end. Had to split the cases and replace all the bearings.
  • Deon
  • Deon's Avatar Topic Author
  • 1964/07/20
Re: Timing Chain
27 Mar 2025 04:39
#910605
I finally got some time to go through a few checks. First problem was the bike would not start again but I found a wire problem by the kill switch so it is starting very well but sounds terrible. I have found that the exhaust pipes 1,2 and 4 are getting warm. Number 3 is stone cold so there is an issue with only running on 3 cylinders. I suppose it could be a Number of reasons for the number 3 not firing as the other pistons.
Hello from the UK
NC750X
KZ650E1
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Timing Chain
27 Mar 2025 04:43
#910606
Given the issue you had with the chain skipping when you rotated the motor I would suggest a compression and leakage test before you get too involved (you may have bent a valve or two :()
  • Deon
  • 1964/07/20
Re: Timing Chain
01 Apr 2025 02:20
#910811
Thanks for advise Wookie. I got round to doing the compression test today. No 1 - 165, No 2  - 175, No 3 - 165 and No 4 - 170.
They all seem fairly consistent on all four. Would you still need a leakage test to check the valves are ok. I dont have a kit to do the test so would have to buy one.
Hello from the UK
NC750X
KZ650E1
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: Timing Chain
01 Apr 2025 02:42
#910813
With those compression readings you are good to go (would be significantly lower with a bent valve), don't worry about buying a leak tester at this stage (you can always buy one at a later date to have to hand if needed)
The following user(s) said Thank You: Gdizard, Rolf1976_KZ900
