hydraulic clutch conversion for stock side cover
- Saablord
03 Feb 2025 11:18
I went down the rabbit hole of designing a conversion plate to run a Concours hydraulic slave on my 82 1000k this past weekend. Initially I was thinking of a plate style sprocket cover and standoffs like you see in aftermarket kits, but I stumbled upon an American Classix kit (no longer made it seems) on eBay and realized that there is enough room to mount a hydraulic slave inside the stock sprocket cover.
The adapter plate route looks feasible to me. This is a 82 1000k with 530 conversion.
Has this been done before? It's a bit difficult to search the forum, but most seem to recommend the cable style retrofit kits or the complete replacement of the sprocket cover.
- sf4t7
Re: hydraulic clutch conversion for stock side cover
03 Feb 2025 11:40
Interesting idea! Is there an easy way to route the hydraulic line to the inside? Let us know what you come up with for a final install.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
03 Feb 2025 11:50
Check out page 23 of my build thread, this just needs the original lifter and a small amount of material removed from the stock cover
The following user(s) said Thank You: sf4t7, howardhb
- Saablord
03 Feb 2025 12:13Interesting idea! Is there an easy way to route the hydraulic line to the inside? Let us know what you come up with for a final install
Ports are currently facing down, but can be rotated 180°. Unfortunately, hole spacing prevents the bleeder from pointing up, but it has to be bled with the cover removed anyways, so 🤷.
I'm planning on routing the clutch hose through the area where the stock cable is routed.
Wookie, I did not initially make it that far in your build thread; very nice solution!
I also spent a little time looking at 650 and mk1 1000 clutch covers I had on hand; looks like the same idea works for those as well!
- sf4t7
03 Feb 2025 15:59
Sorry Guy, I remembered the photos of the slave cylinder and bracket but forgot about the later photo with that handsome model sitting on the bike ! - that one shows the cover installed
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Saablord
03 Feb 2025 22:04
I ordered a few conversion plates for 650/1000/1000J from sendcutsend; I'll update with how they fit... now back to the restoration lol
- cb900f
- Saablord
04 Feb 2025 16:06 - 04 Feb 2025 16:07
Doesn't make sense to me to retain the stock cable driven assembly, and those kits aren't cheap either, if you buy something name brand.
Last edit: 04 Feb 2025 16:07 by Saablord.
04 Feb 2025 16:25
- Bozo
- Ride it like u stole it
04 Feb 2025 17:58 - 04 Feb 2025 18:03
I did the same to my Z1r, the GPZ900R slave fits to the original clutch cover with very minor modification I posted this on forum approx 12years ago). The other Bike "hybrid GPZ1100" has a different mechanism to the clutch rod using ball bearings/ cable, I actually found this to be a better system
Last edit: 04 Feb 2025 18:03 by Bozo.
- bry195
04 Feb 2025 20:54
How is it mounted?
