Small bike red line and max cruising RPM
  • ckahleer
  • ckahleer's Avatar Topic Author
31 Jan 2025 07:47
#908470
I sometimes need to ride at 70mph for about 30 minutes on my KZ305. Am I abusing the bike? Tachometer red line is 10K and the tech is at about 7K. Is there a rule of thumb reguarding red line and max cruising RPM?
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Small bike red line and max cruising RPM
31 Jan 2025 07:55
#908471
My Honda CL 350 loved it at 70MPH. The Harley guys were shocked I could keep up with them. 7k doesn't seem to be too hard on your bike if it is in good shape.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
31 Jan 2025 08:13
#908472
Agree with Steve, if it's in reasonable shape then 7k for 30 mins should be OK (manufacturers have an expectation that small engines will get mercilessly thrashed !!)
  • Injected
  • Injected's Avatar
31 Jan 2025 10:30 - 31 Jan 2025 10:31
#908475
Piston speed is the main concern at high RPM, but with small diameter lightweight pistons it is less of a issue. There should be no issue if plugs and oil are fresh, like Wookie mentioned they were engineered for abuse.
Kawasaki's are built like tanks, unlike Honda's!
I once rode my KZ650 for over 30 minutes at 8,500-9000 RPM with no side effects other than a wee bit of oil in the air box (where it is designed to go)
1978 KZ650B2 modified project
Last edit: 31 Jan 2025 10:31 by Injected. Reason: sp
The following user(s) said Thank You: kimchella
  • Matratt3
  • Matratt3's Avatar
  • 1987 KZ305-B2
24 Feb 2025 16:41
#909356
I was wondering the exact same thing!
I need to keep up on the highway to not get run over.
