Reply to Deon
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Moderator
Reply to Deon
06 Aug 2024 01:39
#902837
You can remove the vented plates on the cam cover, block the four holes with threaded plugs and make or buy flat plates to cover the holes where the reed valves sit. If fitting pods I would suggest you reach out to Zed1015 for a set of his "air corrector" jets (they're not expensive) or you will most likely have running issues
