Oil light?!
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Oil light?!
16 Jun 2024 16:17
#900822
I would start by pulling the wire off the oil switch, if the light stays on then the wire is going to ground before the switch, if the light goes out the switch is bad ( the connection to the switch must be ok for the light to stay on - unless it stays on when disconnected)
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Re: Oil light?!
16 Jun 2024 19:33
#900842
Thank you guys, it was my oil pressure sensor !! I appreciateĀ
Kz750e 1980
