- Thank you received: 2301
Oil light?!
16 Jun 2024 16:17 #900822
by Wookie58
Replied by Wookie58 on topic Oil light?!
I would start by pulling the wire off the oil switch, if the light stays on then the wire is going to ground before the switch, if the light goes out the switch is bad ( the connection to the switch must be ok for the light to stay on - unless it stays on when disconnected)
- Maxbou92
- Thank you received: 4
16 Jun 2024 19:33 #900842
by Maxbou92
Kz750e 1980
Replied by Maxbou92 on topic Oil light?!
Thank you guys, it was my oil pressure sensor !! I appreciateĀ
Kz750e 1980
