OIL you know black gold
  • Kickinchicken
  • Kickinchicken's Avatar Topic Author
14 Jul 2006 15:51
#62013
What grade of oil would anyone recomend. My bike call for 10/40 I put valvoline atv 10/40 in but it gets whitish and there is no wat there is any moisture in that motor. The valvoline specificly said it was good for wet clutches so I gave it a try.
Does anyone use 20/50 any problems like mentioned above or any brand better than another??
  • EddieBoy
  • EddieBoy's Avatar
Re: OIL you know black gold
14 Jul 2006 15:56
#62015
i use 20/50 castrol all year with no problems.
i like valvoline in my V8's ...but i like castrol in smaller high reving engines
  • steell
  • steell's Avatar
14 Jul 2006 16:00
#62016
No moisture in the crankcase? You live in an area with 0% humidity??
Moisture gets into the crankcase via condensation, about the only way to prevent that is to keep it at the same temp all the time.
Taking it on long rides will normally evaporate all the water from the crankcase.
I ran 20w-50 in my 750 twin for awhile, then switched to Rotella 10W-40 and don't notice any difference (except it costs less) :)
  • donthekawguy
  • donthekawguy's Avatar
14 Jul 2006 18:14
#62042
I like Castrol 20/50. NEVER use Penzoil! YUCK!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • steell
  • steell's Avatar
14 Jul 2006 18:33
#62055
Or Quaker State!!
  • Kickinchicken
15 Jul 2006 04:01
#62113
Thanks for the info,what I meant is there is no way that water is leaking in my oil that I know of. Moisture is a given we are next to the Atlantic Ocean and I use my bike for a commuter to and from work, it never gets over 60 kms /hr.:laugh: :dry:
  • oldcoldankles
  • oldcoldankles's Avatar
15 Jul 2006 06:18
#62125
Castrol 10W-40 Grand Prix motorcycle oil is readily available here from both Canadian Tire and Wal-Mart so I use it in both my bikes, changing every 3500km or sooner. At 60 km/hr your bike is just idling, try to run it up to at least 100km/hr to get that moisture out:)
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • trippivot
  • trippivot's Avatar
15 Jul 2006 06:24
#62126
whiteish???
if it looks like milkshake-- you have water in the oil.
just a little evaporates with engine heat but a lot will plug the oil pump after it gets churned and mixed up.
20/50 in summer 10/40 in winter
use motorcycle specific oil due to sheer factor. Auto oil does not handle the transmission sheer and lubrication value goes away in a matter of just a couple miles. even if it still looks like honey.
we had some people next door and the kids would fill the crankcase of his bike with the hose as they were playing. Big mess more than once.
  • arobsum
  • arobsum's Avatar
15 Jul 2006 17:52
#62222
20-w50 is the way to go...
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
15 Jul 2006 18:53
#62236
Castrol in mine. I like the jug it comes in.;)
Quaker state and pennzoil is a parafin based oil.Or so i was told in diesel school. Roy
  • steell
  • steell's Avatar
15 Jul 2006 23:15
#62315
I have to disagree with that (and I have the research to back it up), that's just something the oil companies say in order to get you to spend the extra $$ for their so called "Motorcycle specific oil"
Actual research published by MCN is at the link below.
MCN article
And keep in mind that if that were true you would certainly notice it, the oil would be so thin you would loose oil pressure and when you drained the oil it would run like water.
I don't know about anyone else, but when I drain the oil out of my bike after 2000 miles, it is still thick.
I forgot to mention that a "lot" of members use automotive oil in their bikes, I'd almost bet that combined we have over a million miles of experience with automotive oil in KZ's :)
Post edited by: steell, at: 2006/07/16 03:53
  • nfswift
  • nfswift's Avatar
16 Jul 2006 00:12
#62319
Cool, so I should run wet-clutch friendly 20-50 in my 650 CSR this summer?
